Best way to install push rod tubes for no leaks |
pcdarks |
Jan 22 2021, 10:42 AM
Member Group: Members Posts: 80 Joined: 22-June 13 Member No.: 16,037 Region Association: None |
I'm getting ready to put my 1.7 back together and am wondering what you people do to insure that the push rod tubes don't leak. From what I saw taking it apart this is where most of my leaks came from. Is it possible? or were the tubes designed by the British? thanks.
Superhawk996 |
Jan 22 2021, 10:45 AM
914 Guru Group: Members Posts: 5,824 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
. . . were the tubes designed by the British? (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/aktion035.gif) They all leak eventually. Viton seals are the best bet long term. In my experience, I've had decent success with silicone grease O-ring lubricant from Dow Corning. Helps avoid nicking the o-rings on install and provides a little lubrication to account for thermal expansion contraction. RTV is a no-go IMHO. I've never seen that work. |
Lo-Fi Version | Time is now: 17th May 2024 - 05:57 PM |
