Best way to install push rod tubes for no leaks |
pcdarks |
Jan 22 2021, 10:42 AM
Member Group: Members Posts: 80 Joined: 22-June 13 Member No.: 16,037 Region Association: None |
I'm getting ready to put my 1.7 back together and am wondering what you people do to insure that the push rod tubes don't leak. From what I saw taking it apart this is where most of my leaks came from. Is it possible? or were the tubes designed by the British? thanks.
Rav914 |
Feb 8 2021, 12:15 AM
All-weather fan Group: Members Posts: 738 Joined: 15-April 07 From: WA Member No.: 7,669 Region Association: None |
Viton seals. I've removed the heads three times in the past few years for reasons unrelated to leaking. I replaced the seals each time, never reused them. I also make sure the bores are super clean and then put a fine coat of engine assembly lube on the seals so they don't catch or twist. Zero leaks every time.
Stock pushrod tubes as well. |
Lo-Fi Version | Time is now: 17th May 2024 - 06:02 PM |
