vented 4 lug rotors? |
B2524 |
Jan 23 2021, 12:31 AM
It's a sickness. Group: Members Posts: 72 Joined: 12-November 11 From: Outside Paso Robles CA Member No.: 13,776 Region Association: Northern California |
Is there an easy way to get a vented rotor with a 4 lug hub???
TIA |
Superhawk996 |
Jan 23 2021, 08:34 AM
914 Guru Group: Members Posts: 5,824 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Real question is why do you think you need vented rotors?
Unless you're having serious issues with brake fade, there isn't an advantage to vented rotors. Even if you were having some fade there are other pad compounds that can minimize it. Would be surprised if you're getting fade in a street and/or canyon carving scenario. Track use is completely different. Vented rotors add mass and inertia to a rotating wheel assembly which then impairs vehicle acceleration & deceleration of it's own accord. Basically a net negative to performance unless you're having brake fade issues. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:07 AM |
