Dipstick tube removal, Help needed |
Jan 24 2021, 04:11 PM
914-6 GT in waiting Group: Members Posts: 19,254 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I need to pack up a type 4 engine case for shipping. How do I remove the dipstick tube?
Thanks |
porschetub |
Jan 24 2021, 05:30 PM
Mark I think these are a press fit,not sure if you can easily remove then without damage to the tube....if you can remove them @ all ?
GregAmy |
Jan 24 2021, 05:44 PM
Advanced Member Group: Members Posts: 2,284 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
I tried for my short block's trip to Cali. Couldn't get it out. So I packed around it very, very well and supported the engine on all sides...and FedEx clearly rolled the package through its warehouse, bending the tube.
Jan 24 2021, 05:51 PM
Guys, thanks for the info. I'll just pack it carefully. (IMG:style_emoticons/default/beerchug.gif)
iankarr |
Jan 24 2021, 06:28 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,472 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Tape a slightly longer block of wood to it
Jan 24 2021, 06:40 PM
Tape a slightly longer block of wood to it (IMG:style_emoticons/default/agree.gif) That’s what I was planning. |
VaccaRabite |
Jan 24 2021, 09:29 PM
En Garde! Group: Admin Posts: 13,437 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I’ve removed the dipstick tube before on my engine. Lots of heat on the boss and tap it up using a block. Wasn’t easy. I was changing from the bus tube to the 914 tube.
In install I put the tube in the freezer and heated the hell out of the boss. Tapped the tube in no problem. Zach |
Lo-Fi Version | Time is now: 3rd May 2024 - 11:15 PM |
