914Rubber Rear Trailing Arm Bushings, did I get the wrong ones? |
bbrock |
Jan 25 2021, 08:54 PM
@Mikey914
I bought a set of the rubber rear trailing arm bushings in the 914Rubber GB when they first came out (can't remember when that was). I am just now getting around to installing them and ran into a problem. I did a test fit to see how hard they would be to install and was shocked to find I could easily slide them into the trailing arms by hand AND could slide the pivot shaft in by hand. In fact, I'm not seeing much difference from the polygraphite bushings they are meant to replace. If anything, these fit even looser. I'm wondering I was sent the wrong ones. My understanding is the rubber bushings should be a tight fit and require a press or similar to install as seen in Ian's video. Is there a good way to know what I have? These are stamped "WDG" on the flange side which is different from the stamping on the first set of bushings I bought. |
Arno914 |
Jan 26 2021, 01:49 AM
Member Group: Members Posts: 233 Joined: 13-May 20 From: near Frankfurt, Germany Member No.: 24,260 Region Association: Germany |
As far as I have learned, suspension rubber bushings are designed to be press fit on the shaft and the tube. Movement is only within the rubber itself. (Thats why you must lower the car on ist wheels before tightening the lock nuts.) Any movement between the bushing and the corresponding parts will eventually lead to (rapid) detoriation. Never use grease or oil for assembly. Turpentine works.
Lo-Fi Version | Time is now: 14th May 2024 - 12:13 AM |
