914Rubber Rear Trailing Arm Bushings, did I get the wrong ones? |
bbrock |
Jan 25 2021, 08:54 PM
@Mikey914
I bought a set of the rubber rear trailing arm bushings in the 914Rubber GB when they first came out (can't remember when that was). I am just now getting around to installing them and ran into a problem. I did a test fit to see how hard they would be to install and was shocked to find I could easily slide them into the trailing arms by hand AND could slide the pivot shaft in by hand. In fact, I'm not seeing much difference from the polygraphite bushings they are meant to replace. If anything, these fit even looser. I'm wondering I was sent the wrong ones. My understanding is the rubber bushings should be a tight fit and require a press or similar to install as seen in Ian's video. Is there a good way to know what I have? These are stamped "WDG" on the flange side which is different from the stamping on the first set of bushings I bought. |
pete000 |
Jan 26 2021, 08:52 PM
Senior Member Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
Well at least they were easy to install by hand with out special tools, clamps, presses, lubes ! Hope it all works properly for you !
Lo-Fi Version | Time is now: 14th May 2024 - 05:04 AM |
