Modern trailing arms for the 914?, 986 carriers/calipers/e-brake, more adjustability, more tire? |
horizontally-opposed |
Jan 26 2021, 12:21 PM
Advanced Member Group: Members Posts: 3,432 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
I've been reviewing past discussions on these (links below) off and on, having test fit a 215/60R15 Pirelli P6000 on a 911R wheel into both rear fenders of my narrow-body 914. It seems doable, but it's going to take some massaging on the outer fender, custom spacers, and—maybe—narrowed trailing arms. Which got me to thinking about the current state of the 914 trailing arm, which is the same it's been since 1970.
Basically, those heavy, non-adjustable steel trailing arms are one of the very few things on the 914 that hasn't been addressed or evolved by the aftermarket. I'm running PMB-rebuilt trailing arms with PMB-rebuilt calipers, and can redo them again with reinforcements and/or some reshaping, but I wonder how hard would it be to do blade-type trailing arms of similar strength with less weight and/or more adjustment. Could a 911 spring plate, or a triangulated or otherwise reinforced version of it, be adapted? Looking at the basic design of the 914 arm, it doesn't look all that complicated, but I'm no engineer. EDIT: Possible use of a machined 986 wheel carrier, an aluminum casting by Brembo that incorporates the 986 e-brake and 986 four-piston caliper mounts, comes up later—a very interesting idea from @Chris914n6, particularly as the castings are available for $100-200ea used or new from Porsche. Bolting that carrier to a new steel trailing arm with a lower damper mount seems viable to me, but here to learn. The custom work to narrow factory 914 trailing arms looks extensive, but has been done by both @914timo and @sixnotfour as well as, it looks like, Rich Johnson. I could see doing it in the process of moving to 911 e-brakes and 986 2.5 brakes, maybe, but I wonder if a group buy might attract a 914 vendor we all want to support? Relevant threads: http://www.914world.com/bbs2/index.php?sho...p;#entry1247827 http://www.914world.com/bbs2/index.php?sho...ailing&st=0 http://www.914world.com/bbs2/index.php?sho...238144&st=0 http://www.914world.com/bbs2/index.php?sho...234391&st=0 |
Jan 29 2021, 05:06 PM
Open to all ideas, as this is all about spitballin' at this stage. (IMG:style_emoticons/default/beerchug.gif)
With that said, and pursuant to @mb911's post above, I actually think the suspension concepts of the 914 are pretty good. Sure, multi-link, double A-arm, etc are better when it comes to camber gain, etc—but 914s are plenty fast and able to process bumps even by modern standards. The light weight and long wheelbase definitely help. And, to my mind, the best solution is a part that bolts on—so it's a reversible mod. That broadens the customer base. Cutting the tub is a nonstarter for a lot of folks. I reached out to an overqualified acquaintance who might be able to help with some early feedback on ballpark weight loss vs rough costs for the first pair of trailing arms (development, setup, creation) and then more in small qty. We'll see if he laughs me out of the room. Meantime, also reached out to one of the 2-3 techs I would hire to rebuild/narrow/reinforce/five-lug/add 911 e-brakes/repaint/re-bush/re-bearing/etc for what he might charge. Asked him to do so on the basis of one stop, so no procurement on my side. First response: "$2500?" Then, as the scope of the work set in, "Could be more like $5k, with no brakes other than the parking brakes." Remember, this is checkbook math, not DIY—and some won't need to do some of those things, and can subtract accordingly, but checkbook math is the fair comp and I suspect $3500-5500 is a decent guesstimate for rebuilt/modded 50yo steel trailing arms. |
Lo-Fi Version | Time is now: 28th May 2024 - 10:49 AM |
