Modern trailing arms for the 914?, 986 carriers/calipers/e-brake, more adjustability, more tire? |
horizontally-opposed |
Jan 26 2021, 12:21 PM
Advanced Member Group: Members Posts: 3,432 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
I've been reviewing past discussions on these (links below) off and on, having test fit a 215/60R15 Pirelli P6000 on a 911R wheel into both rear fenders of my narrow-body 914. It seems doable, but it's going to take some massaging on the outer fender, custom spacers, and—maybe—narrowed trailing arms. Which got me to thinking about the current state of the 914 trailing arm, which is the same it's been since 1970.
Basically, those heavy, non-adjustable steel trailing arms are one of the very few things on the 914 that hasn't been addressed or evolved by the aftermarket. I'm running PMB-rebuilt trailing arms with PMB-rebuilt calipers, and can redo them again with reinforcements and/or some reshaping, but I wonder how hard would it be to do blade-type trailing arms of similar strength with less weight and/or more adjustment. Could a 911 spring plate, or a triangulated or otherwise reinforced version of it, be adapted? Looking at the basic design of the 914 arm, it doesn't look all that complicated, but I'm no engineer. EDIT: Possible use of a machined 986 wheel carrier, an aluminum casting by Brembo that incorporates the 986 e-brake and 986 four-piston caliper mounts, comes up later—a very interesting idea from @Chris914n6, particularly as the castings are available for $100-200ea used or new from Porsche. Bolting that carrier to a new steel trailing arm with a lower damper mount seems viable to me, but here to learn. The custom work to narrow factory 914 trailing arms looks extensive, but has been done by both @914timo and @sixnotfour as well as, it looks like, Rich Johnson. I could see doing it in the process of moving to 911 e-brakes and 986 2.5 brakes, maybe, but I wonder if a group buy might attract a 914 vendor we all want to support? Relevant threads: http://www.914world.com/bbs2/index.php?sho...p;#entry1247827 http://www.914world.com/bbs2/index.php?sho...ailing&st=0 http://www.914world.com/bbs2/index.php?sho...238144&st=0 http://www.914world.com/bbs2/index.php?sho...234391&st=0 |
Feb 1 2021, 01:03 PM
^ Good inputs.
Would be curious for an engineer's take on Rory's very cool looking solution, but figure that's only added labor on top of the rebuild/reinforcement services available for $1800-2400 once a 911 e-brake is grafted into place. Also wonder how much weight that saved, Rory? I sure dig the look… $2000-4000 for a pair of modified 50yo trailing arms would seem to open up possibilities for new trailing arms—and perhaps some weight savings come instead from 986 or 930 calipers instead of two-piston steel Ate calipers and/or two-piece rotors. But it's going to take an engineer to see a smart way forward. |
rgalla9146 |
Feb 1 2021, 05:43 PM
Advanced Member Group: Members Posts: 4,555 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
^ Good inputs. Would be curious for an engineer's take on Rory's very cool looking solution, but figure that's only added labor on top of the rebuild/reinforcement services available for $1800-2400 once a 911 e-brake is grafted into place. Also wonder how much weight that saved, Rory? I sure dig the look… $2000-4000 for a pair of modified 50yo trailing arms would seem to open up possibilities for new trailing arms—and perhaps some weight savings come instead from 986 or 930 calipers instead of two-piston steel Ate calipers and/or two-piece rotors. But it's going to take an engineer to see a smart way forward. Doooh! I didn't weigh before and after. But.... I wanted to add stiffness in a different way. The commonly available kit was not appealing to me. Our cars have virtually no multi-layer metal features or reinforcements. They do have complex shapes and boxes which provide very strong lightweight assemblies. My picture shows what was removed and what was not added. What was added was maybe 1 1/2lb. of heavy wall 2" and 3" tubing. The stiffening kit and removed discs weigh 2lbs 14oz.....~3lbs then 1 1/2 lbs went back on. So a net loss of 1.5 lbs per side. Unsprung. What really matters would be performance in a torsional rigidity test. That can not be done with a postal scale Attached thumbnail(s) |
Lo-Fi Version | Time is now: 19th May 2024 - 10:08 AM |
