Modern trailing arms for the 914?, 986 carriers/calipers/e-brake, more adjustability, more tire? |
horizontally-opposed |
Jan 26 2021, 12:21 PM
Advanced Member Group: Members Posts: 3,431 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
I've been reviewing past discussions on these (links below) off and on, having test fit a 215/60R15 Pirelli P6000 on a 911R wheel into both rear fenders of my narrow-body 914. It seems doable, but it's going to take some massaging on the outer fender, custom spacers, and—maybe—narrowed trailing arms. Which got me to thinking about the current state of the 914 trailing arm, which is the same it's been since 1970.
Basically, those heavy, non-adjustable steel trailing arms are one of the very few things on the 914 that hasn't been addressed or evolved by the aftermarket. I'm running PMB-rebuilt trailing arms with PMB-rebuilt calipers, and can redo them again with reinforcements and/or some reshaping, but I wonder how hard would it be to do blade-type trailing arms of similar strength with less weight and/or more adjustment. Could a 911 spring plate, or a triangulated or otherwise reinforced version of it, be adapted? Looking at the basic design of the 914 arm, it doesn't look all that complicated, but I'm no engineer. EDIT: Possible use of a machined 986 wheel carrier, an aluminum casting by Brembo that incorporates the 986 e-brake and 986 four-piston caliper mounts, comes up later—a very interesting idea from @Chris914n6, particularly as the castings are available for $100-200ea used or new from Porsche. Bolting that carrier to a new steel trailing arm with a lower damper mount seems viable to me, but here to learn. The custom work to narrow factory 914 trailing arms looks extensive, but has been done by both @914timo and @sixnotfour as well as, it looks like, Rich Johnson. I could see doing it in the process of moving to 911 e-brakes and 986 2.5 brakes, maybe, but I wonder if a group buy might attract a 914 vendor we all want to support? Relevant threads: http://www.914world.com/bbs2/index.php?sho...p;#entry1247827 http://www.914world.com/bbs2/index.php?sho...ailing&st=0 http://www.914world.com/bbs2/index.php?sho...238144&st=0 http://www.914world.com/bbs2/index.php?sho...234391&st=0 |
Jan 26 2021, 10:21 PM
Silver cookie setup looks good to me. (IMG:style_emoticons/default/chowtime.gif)
As for pillows… (IMG:style_emoticons/default/biggrin.gif) yeah maybe for all-seasons. But 185/70 front & 215/60R15 rear was standard for a 1973 Carrera RS while 195/65 front & 215/60R15 rear is standard for a 911 SC and Carrera 3.2. So that's a pretty attractive "maximum" setup for a narrow-body 914 with 200-250 hp—and Avon CR6ZZ are available in those sizes and were available from Roger Kraus Racing in three compounds last time I bought a set of 185/70s. Pirelli P6000 and CN36 are available in those sizes, too—and the revisions might accept 225/50R15 rears as well, which opens the door to Toyo RA1s and other interesting options if the car ever sees a track again. It's going to take some work, but others have done it—on both narrow 914s as well as narrow early 911s—and whatever the work…it's a lot less work than GT flares and painting both sides of the car. Figure it can be pulled for now, and perhaps redone to a higher standard with the next paint job. Need to put some more miles and rock chips on this one first. (IMG:style_emoticons/default/smile.gif) Attached thumbnail(s) Attached image(s) |
Lo-Fi Version | Time is now: 7th May 2024 - 10:34 AM |
