Modern trailing arms for the 914?, 986 carriers/calipers/e-brake, more adjustability, more tire? |
horizontally-opposed |
Jan 26 2021, 12:21 PM
Advanced Member Group: Members Posts: 3,431 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
I've been reviewing past discussions on these (links below) off and on, having test fit a 215/60R15 Pirelli P6000 on a 911R wheel into both rear fenders of my narrow-body 914. It seems doable, but it's going to take some massaging on the outer fender, custom spacers, and—maybe—narrowed trailing arms. Which got me to thinking about the current state of the 914 trailing arm, which is the same it's been since 1970.
Basically, those heavy, non-adjustable steel trailing arms are one of the very few things on the 914 that hasn't been addressed or evolved by the aftermarket. I'm running PMB-rebuilt trailing arms with PMB-rebuilt calipers, and can redo them again with reinforcements and/or some reshaping, but I wonder how hard would it be to do blade-type trailing arms of similar strength with less weight and/or more adjustment. Could a 911 spring plate, or a triangulated or otherwise reinforced version of it, be adapted? Looking at the basic design of the 914 arm, it doesn't look all that complicated, but I'm no engineer. EDIT: Possible use of a machined 986 wheel carrier, an aluminum casting by Brembo that incorporates the 986 e-brake and 986 four-piston caliper mounts, comes up later—a very interesting idea from @Chris914n6, particularly as the castings are available for $100-200ea used or new from Porsche. Bolting that carrier to a new steel trailing arm with a lower damper mount seems viable to me, but here to learn. The custom work to narrow factory 914 trailing arms looks extensive, but has been done by both @914timo and @sixnotfour as well as, it looks like, Rich Johnson. I could see doing it in the process of moving to 911 e-brakes and 986 2.5 brakes, maybe, but I wonder if a group buy might attract a 914 vendor we all want to support? Relevant threads: http://www.914world.com/bbs2/index.php?sho...p;#entry1247827 http://www.914world.com/bbs2/index.php?sho...ailing&st=0 http://www.914world.com/bbs2/index.php?sho...238144&st=0 http://www.914world.com/bbs2/index.php?sho...234391&st=0 |
Montreal914 |
Jan 28 2021, 10:25 AM
Senior Member Group: Members Posts: 1,545 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
A few years back, planning on my 5 lugs upgrade, I had a nice set of 15 x 6 Fuchs. After reading that the tire selection is greater with the 16", I sold them and got a set of 16 x 6. (IMG:style_emoticons/default/headbang.gif)
I am currently preparing my narrow body car for paint and will eventually reassemble it with the 5 lugs. I am puzzled as to what summer tire selection there actually is in the 16" (IMG:style_emoticons/default/sad.gif) . It feels like the selection is greater in the 15", or am I missing something... (IMG:style_emoticons/default/confused24.gif) Being in SoCal, I am looking at summer tires, but don't want too much of a modern look. I understand that by switching to 16, I walked away from the proper era look (IMG:style_emoticons/default/headbang.gif) Sorry to jump in the OP's thread, but I know Pete is thoroughly investigating the tire file... I read one of your post talking about the Michelin Pilot Sport AS3 205/55/16. I am not sure if this model is still available though... Interesting topic! (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/popcorn[1].gif) |
Jan 28 2021, 10:59 AM
A few years back, planning on my 5 lugs upgrade, I had a nice set of 15 x 6 Fuchs. After reading that the tire selection is greater with the 16", I sold them and got a set of 16 x 6. (IMG:style_emoticons/default/headbang.gif) I am currently preparing my narrow body car for paint and will eventually reassemble it with the 5 lugs. I am puzzled as to what summer tire selection there actually is in the 16" (IMG:style_emoticons/default/sad.gif) . It feels like the selection is greater in the 15", or am I missing something... (IMG:style_emoticons/default/confused24.gif) Being in SoCal, I am looking at summer tires, but don't want too much of a modern look. I understand that by switching to 16, I walked away from the proper era look (IMG:style_emoticons/default/headbang.gif) Sorry to jump in the OP's thread, but I know Pete is thoroughly investigating the tire file... I read one of your post talking about the Michelin Pilot Sport AS3 205/55/16. I am not sure if this model is still available though... Interesting topic! (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/popcorn[1].gif) 16x6 allows for some GREAT tires—from (at last check) the Pilot Sport AS3, which has a simple sidewall and an "old enough" looking tread pattern and more than enough performance and feel for me on the street, to some pretty serious R-compound tires for autocross and track use. Last I checked, not only Toyo RA1 but also Michelin Cups and some others. The good news with 205/55R16 is it was original fit for Porsches on 16-inch alloy wheels from 1975~ through 2004 (last of the 986s on 16s) as well as a ton of other performance cars built in big numbers, such as the Subaru WRX. The bad news is sneaking them into the rear fenders. I had no problems with 205/60R15 other than a bit of rubbing on the inside, so you might get them in. Some 914s seem to have less clearance than others. You may also have a bit of interference up front depending on where your wheels sit in the fenders (I use spacers up there, and 185/70s can occasionally just barely catch my LE-style spoiler with the right amount of steering lock and suspension compression, such as on the way into a certain kind of driveway…though it's ultra rare and I've seen zero damage). But if you sort them, as many have, 205/55R16 is a wonderful size for a narrow body 914 and probably the ultimate performance setup without resorting to much in the way of trickery. Looks like the AS3s are available in H-rated or V-rated for $135-140ea, but may be on closeout? But whatever, I doubt availability or selection will be a problem with 205/55R16. 225/50R16 may be a bit more of an issue, and 245/45R16 has already been an issue (being down to track tires or Fuzion, take your pick) but there are some very good 245/45 options out there again. |
Lo-Fi Version | Time is now: 7th May 2024 - 12:56 AM |
