Modern trailing arms for the 914?, 986 carriers/calipers/e-brake, more adjustability, more tire? |
horizontally-opposed |
Jan 26 2021, 12:21 PM
Advanced Member Group: Members Posts: 3,431 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
I've been reviewing past discussions on these (links below) off and on, having test fit a 215/60R15 Pirelli P6000 on a 911R wheel into both rear fenders of my narrow-body 914. It seems doable, but it's going to take some massaging on the outer fender, custom spacers, and—maybe—narrowed trailing arms. Which got me to thinking about the current state of the 914 trailing arm, which is the same it's been since 1970.
Basically, those heavy, non-adjustable steel trailing arms are one of the very few things on the 914 that hasn't been addressed or evolved by the aftermarket. I'm running PMB-rebuilt trailing arms with PMB-rebuilt calipers, and can redo them again with reinforcements and/or some reshaping, but I wonder how hard would it be to do blade-type trailing arms of similar strength with less weight and/or more adjustment. Could a 911 spring plate, or a triangulated or otherwise reinforced version of it, be adapted? Looking at the basic design of the 914 arm, it doesn't look all that complicated, but I'm no engineer. EDIT: Possible use of a machined 986 wheel carrier, an aluminum casting by Brembo that incorporates the 986 e-brake and 986 four-piston caliper mounts, comes up later—a very interesting idea from @Chris914n6, particularly as the castings are available for $100-200ea used or new from Porsche. Bolting that carrier to a new steel trailing arm with a lower damper mount seems viable to me, but here to learn. The custom work to narrow factory 914 trailing arms looks extensive, but has been done by both @914timo and @sixnotfour as well as, it looks like, Rich Johnson. I could see doing it in the process of moving to 911 e-brakes and 986 2.5 brakes, maybe, but I wonder if a group buy might attract a 914 vendor we all want to support? Relevant threads: http://www.914world.com/bbs2/index.php?sho...p;#entry1247827 http://www.914world.com/bbs2/index.php?sho...ailing&st=0 http://www.914world.com/bbs2/index.php?sho...238144&st=0 http://www.914world.com/bbs2/index.php?sho...234391&st=0 |
Chris914n6 |
Jan 29 2021, 02:16 AM
Jackstands are my life. Group: Members Posts: 3,316 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
~21.5 lbs as seen. Scale might not be 100% accurate.
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1611908166.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1611908166.2.jpg) |
mepstein |
Jan 29 2021, 07:40 AM
914-6 GT in waiting Group: Members Posts: 19,256 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
~21.5 lbs as seen. Scale might not be 100% accurate. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1611908166.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1611908166.2.jpg) So without the hub, bearing, bracket and shaft, fifteen-ish, maybe? |
Jan 29 2021, 10:05 AM
~21.5 lbs as seen. Scale might not be 100% accurate. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1611908166.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1611908166.2.jpg) So without the hub, bearing, bracket and shaft, fifteen-ish, maybe? Not much to be done with the wheel bearing, but the shaft and hub might be a place to apply better materials. Maybe also set up for four or five lug wheels. Anyway, suspect your guess is within a pound or two. |
mepstein |
Jan 29 2021, 10:34 AM
~21.5 lbs as seen. Scale might not be 100% accurate. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1611908166.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1611908166.2.jpg) So without the hub, bearing, bracket and shaft, fifteen-ish, maybe? Not much to be done with the wheel bearing, but the shaft and hub might be a place to apply better materials. Maybe also set up for four or five lug wheels. Anyway, suspect your guess is within a pound or two. Largest, easiest chunk of weight would be aluminum calipers. Eric did a run but I don't think there was ever a huge demand. I think it was the price that held people back. I think part of the reason a stock 914 is such a joy to drive is the light, narrow tires. They may not provide ultimate traction but feel light and smooth and let the car "dance" over the road. "I've been testing factory and aftermarket Porsches on road and track since 1997. Long ago lost count of how many cars, track days, and road tests. Along the way, the cars that hit the sweet spot and were "soul connected" were the ones that stood out. They were often less is more, such as a 986 2.5 that was just plain more fun to drive than a 993 Turbo. Or the 987.2 Boxster Spyder, which was far more than the sum of its parts—and probably quicker over the road in the hands of more drivers than a contemporary GT3. And, dare I say it, more fun despite a merely wonderful engine instead of that insane Mezger. There are a lot of other examples, but the 914 stands tall in this regard—and that goes for virtually any good 914. I get this. I've ridden and raced bicycles all my life. I ran a bike shop for 6 years so I rode hundreds of different bikes than just mine. Most of the bikes I owned were top of the line, great bicycles and did there job well. Two of them were outstanding and I have not been able to duplicate the feel. So maybe we should be aiming to hit that sweet spot with a 914. I've never driven a 911RS but it seems to get described in that way. So maybe we need to make a 914RS. A magical riding car that can be duplicated. |
Lo-Fi Version | Time is now: 7th May 2024 - 04:48 PM |
