Modern trailing arms for the 914?, 986 carriers/calipers/e-brake, more adjustability, more tire? |
horizontally-opposed |
Jan 26 2021, 12:21 PM
Advanced Member Group: Members Posts: 3,431 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
I've been reviewing past discussions on these (links below) off and on, having test fit a 215/60R15 Pirelli P6000 on a 911R wheel into both rear fenders of my narrow-body 914. It seems doable, but it's going to take some massaging on the outer fender, custom spacers, and—maybe—narrowed trailing arms. Which got me to thinking about the current state of the 914 trailing arm, which is the same it's been since 1970.
Basically, those heavy, non-adjustable steel trailing arms are one of the very few things on the 914 that hasn't been addressed or evolved by the aftermarket. I'm running PMB-rebuilt trailing arms with PMB-rebuilt calipers, and can redo them again with reinforcements and/or some reshaping, but I wonder how hard would it be to do blade-type trailing arms of similar strength with less weight and/or more adjustment. Could a 911 spring plate, or a triangulated or otherwise reinforced version of it, be adapted? Looking at the basic design of the 914 arm, it doesn't look all that complicated, but I'm no engineer. EDIT: Possible use of a machined 986 wheel carrier, an aluminum casting by Brembo that incorporates the 986 e-brake and 986 four-piston caliper mounts, comes up later—a very interesting idea from @Chris914n6, particularly as the castings are available for $100-200ea used or new from Porsche. Bolting that carrier to a new steel trailing arm with a lower damper mount seems viable to me, but here to learn. The custom work to narrow factory 914 trailing arms looks extensive, but has been done by both @914timo and @sixnotfour as well as, it looks like, Rich Johnson. I could see doing it in the process of moving to 911 e-brakes and 986 2.5 brakes, maybe, but I wonder if a group buy might attract a 914 vendor we all want to support? Relevant threads: http://www.914world.com/bbs2/index.php?sho...p;#entry1247827 http://www.914world.com/bbs2/index.php?sho...ailing&st=0 http://www.914world.com/bbs2/index.php?sho...238144&st=0 http://www.914world.com/bbs2/index.php?sho...234391&st=0 |
Jan 29 2021, 11:35 AM
This one would take a village to get done, but I think it's within the realm of possibility between our contacts and even some of the talent here. And I may have a "cost no object" buyer who might underwrite the most expensive pair (the first ones), as he was already thinking along same lines when I mentioned them. He's getting over Covid, and we were talking cars to keep him distracted. He's got a lot of other stuff, but loves his 914. And if a number of us signed on for a group buy…
Four billet aluminum ends won't be cheap, but they should be doable. Best way would be to incorporate choices such as which of three bushings/bearings up front and ears for 914, 930, or 986 calipers in the rear—leaving it up to the customer to move to 911 e-brake, RSR, or spot calipers. Or no e-brake. Carbon or lightweight steel blades would probably be the "hard" part—after proper/safe design and FEA, that is. |
Lo-Fi Version | Time is now: 7th May 2024 - 06:52 AM |
