Modern trailing arms for the 914?, 986 carriers/calipers/e-brake, more adjustability, more tire? |
horizontally-opposed |
Jan 26 2021, 12:21 PM
Advanced Member Group: Members Posts: 3,431 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
I've been reviewing past discussions on these (links below) off and on, having test fit a 215/60R15 Pirelli P6000 on a 911R wheel into both rear fenders of my narrow-body 914. It seems doable, but it's going to take some massaging on the outer fender, custom spacers, and—maybe—narrowed trailing arms. Which got me to thinking about the current state of the 914 trailing arm, which is the same it's been since 1970.
Basically, those heavy, non-adjustable steel trailing arms are one of the very few things on the 914 that hasn't been addressed or evolved by the aftermarket. I'm running PMB-rebuilt trailing arms with PMB-rebuilt calipers, and can redo them again with reinforcements and/or some reshaping, but I wonder how hard would it be to do blade-type trailing arms of similar strength with less weight and/or more adjustment. Could a 911 spring plate, or a triangulated or otherwise reinforced version of it, be adapted? Looking at the basic design of the 914 arm, it doesn't look all that complicated, but I'm no engineer. EDIT: Possible use of a machined 986 wheel carrier, an aluminum casting by Brembo that incorporates the 986 e-brake and 986 four-piston caliper mounts, comes up later—a very interesting idea from @Chris914n6, particularly as the castings are available for $100-200ea used or new from Porsche. Bolting that carrier to a new steel trailing arm with a lower damper mount seems viable to me, but here to learn. The custom work to narrow factory 914 trailing arms looks extensive, but has been done by both @914timo and @sixnotfour as well as, it looks like, Rich Johnson. I could see doing it in the process of moving to 911 e-brakes and 986 2.5 brakes, maybe, but I wonder if a group buy might attract a 914 vendor we all want to support? Relevant threads: http://www.914world.com/bbs2/index.php?sho...p;#entry1247827 http://www.914world.com/bbs2/index.php?sho...ailing&st=0 http://www.914world.com/bbs2/index.php?sho...238144&st=0 http://www.914world.com/bbs2/index.php?sho...234391&st=0 |
Jan 31 2021, 11:29 AM
And yet another option from Elephant…
Not sure I see the need for ride-height adjust with all of the kits available to do the same with 914 rear dampers, but then again, I still haven't bought one of those sets. Might be nice to fine-tune the ride height and even corner balance the car with my less than exotic Bilstein HD/Weltmeister setup—particularly if it's part of the bargain in a trailing arm upgrade. No need to replace springs I like with threaded sleeves and new springs of the same rate. Attached thumbnail(s) |
stownsen914 |
Jan 31 2021, 12:21 PM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
A while back I looked into redesigning the 914 rear suspension for my racecar. The options are a bit limited due to the relatively wide flat 4 or 6 engine being in the way. A 911 trailing arm would be a great option, if you could get it to fit. But there isn't room for the inner mount.
Dual wishbone type suspension is an option, but of course would mean a lot of modifications to to the chassis. I've seen it done on a few tube frame 914 racecars. I've also seen stouter trailing arms like the ones on Sheridan's 914. The challenge is twofold for the 914 - the trailing arms flex, and the chassis in the rear suspension area needs reinforcement too. In my case I added a lot of tubing to the car when I built it to strengthen the chassis. The trailing arms are just stock one with the welded reinforcement kit. Someday when I re-do the rear suspension, I'm planning a custom trailing arm with the adjustments at the hub, similar to what Sheridan did. |
Lo-Fi Version | Time is now: 7th May 2024 - 03:24 AM |
