Modern trailing arms for the 914?, 986 carriers/calipers/e-brake, more adjustability, more tire? |
horizontally-opposed |
Jan 26 2021, 12:21 PM
Advanced Member Group: Members Posts: 3,431 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
I've been reviewing past discussions on these (links below) off and on, having test fit a 215/60R15 Pirelli P6000 on a 911R wheel into both rear fenders of my narrow-body 914. It seems doable, but it's going to take some massaging on the outer fender, custom spacers, and—maybe—narrowed trailing arms. Which got me to thinking about the current state of the 914 trailing arm, which is the same it's been since 1970.
Basically, those heavy, non-adjustable steel trailing arms are one of the very few things on the 914 that hasn't been addressed or evolved by the aftermarket. I'm running PMB-rebuilt trailing arms with PMB-rebuilt calipers, and can redo them again with reinforcements and/or some reshaping, but I wonder how hard would it be to do blade-type trailing arms of similar strength with less weight and/or more adjustment. Could a 911 spring plate, or a triangulated or otherwise reinforced version of it, be adapted? Looking at the basic design of the 914 arm, it doesn't look all that complicated, but I'm no engineer. EDIT: Possible use of a machined 986 wheel carrier, an aluminum casting by Brembo that incorporates the 986 e-brake and 986 four-piston caliper mounts, comes up later—a very interesting idea from @Chris914n6, particularly as the castings are available for $100-200ea used or new from Porsche. Bolting that carrier to a new steel trailing arm with a lower damper mount seems viable to me, but here to learn. The custom work to narrow factory 914 trailing arms looks extensive, but has been done by both @914timo and @sixnotfour as well as, it looks like, Rich Johnson. I could see doing it in the process of moving to 911 e-brakes and 986 2.5 brakes, maybe, but I wonder if a group buy might attract a 914 vendor we all want to support? Relevant threads: http://www.914world.com/bbs2/index.php?sho...p;#entry1247827 http://www.914world.com/bbs2/index.php?sho...ailing&st=0 http://www.914world.com/bbs2/index.php?sho...238144&st=0 http://www.914world.com/bbs2/index.php?sho...234391&st=0 |
914forme |
Feb 2 2021, 10:32 AM
Pete While I find the topic intriguing I wonder what the real end game is.
Tire technology has outpaced suspension design over the last 50 years. So now unless you racing competitively in auto crossing at the national level I would not worry about 10mm of sedition width. Slap on a set of DOT R compound tires, add a set of fender liners, and go drive. The fender liners are needed to avoid the small upward dents you get from all the rocks flying up under the fenders. As little as people drive their 914s you get years out of the tires. And well they are way better than the Dunlops my dad had to choose from in 1976 when he got his 914-6. Remaking the arm, while possible would exceed the 2-3K you would spend to have an arm customized. Via Chris. Or you can do Rory's design and it works also, just to a lesser degree than Chris' solution, but it does provide a solution that can easily be done in your garage. I had an idea on how to duplicate Chris efforts, but chose to pay him for his intellectual property. Sometimes it is worth supporting the vendors that make this hobby what it is, and the community. |
Lo-Fi Version | Time is now: 7th May 2024 - 02:37 PM |
