x-faktory T4, 1911 T4 with EFI/ITBs |
x-faktory |
Jan 26 2021, 02:19 PM
Newbie Group: Members Posts: 21 Joined: 16-August 13 From: PNW Member No.: 16,261 Region Association: Pacific Northwest |
Some of you may be aware of my 911 engine builds, but...I've decided on building a T4-1911.....I was quickly going down the rabbit hole with bigger/better, but then reminded myself of one of the primary goals......and that is to help configure the RHD T'body design that I am using on the 911 builds... to be used for the 4 cylinder engines...starting with the Type 4. Parts are arriving and here is a sneak peek at the 1st units, mounted to manifolds.......
Stay tuned as parts for the build are arriving daily regards, al |
Aerostatwv |
Jan 26 2021, 02:24 PM
Member Group: Members Posts: 116 Joined: 13-July 11 From: WV Member No.: 13,315 Region Association: MidAtlantic Region |
Watching. Thanks!
AfricanHijinx |
Jan 26 2021, 02:26 PM
Member Group: Members Posts: 132 Joined: 12-April 11 From: Snohomish WA Member No.: 12,928 Region Association: Pacific Northwest |
those look great
x-faktory |
Jan 26 2021, 02:30 PM
These should work great too....i've been using the RHD on 911 projects with much success. This is the 1st T4, but should work equally well.
regards, al |
JamesM |
Jan 26 2021, 02:34 PM
Senior Member Group: Members Posts: 1,888 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
(IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif)
Curious to hear all the specifics! For starters, which ITBs are you using? What diameter? |
jd74914 |
Jan 26 2021, 02:57 PM
Its alive Group: Members Posts: 4,776 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Looking forward to seeing details too! Looks like they are from RHD Engineering in AU ( https://racehead.com.au/product-category/throttle-bodies/ ) |
rhodyguy |
Jan 26 2021, 03:40 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,060 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Bodies and tall Vstacks look very similar to the BMW 10 kit too. Except for the intakes. Not so sure you could run them with the rain tray in place. It could be a little spendy all in.
x-faktory |
Jan 26 2021, 04:22 PM
Yes, as stated in the initial post, these are made by RHD. I worked with them a couple of years ago to configure their design for the 911 engine,,,and that turned out very well....now i am working with them to configure for the Type 4, and then the 1,2,3.
These particular units are the very 1st made to work with these manifolds...it required RHD (Rama) to design some custom brackets to ensure that the linkage crossbar would clear, etc....but these are looking good. They are 42mm and will be used on a 1911 build....mild hot rod 914 engine with 1.8 heads, Kerry Hunter headers, Microsquirt etc....my 1st Type 4 build, so bear with me.... If too tall, the bottom spacer can be removed......... |
JmuRiz |
Jan 27 2021, 12:17 PM
914 Guru Group: Members Posts: 5,423 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Very cool, do you already have the parts or can you bump it to a 2056? That combo with tuned EFI would be a blast.
I'm still trying to justify the price for one of your systems on my 2.7 build... |
Mark Henry |
Jan 27 2021, 12:22 PM
Looks a lot like the motorcycle TB's I made.
(IMG:http://www.914world.com/bbs2/uploads/post-26-1385084470_thumb.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-26-1385084492.jpg) |
pete000 |
Jan 27 2021, 06:32 PM
Always wanted to go this route on my 914-4...
racerbvd |
Jan 27 2021, 06:38 PM
Advanced Member Group: Members Posts: 2,368 Joined: 3-February 03 From: Sunny FL. Member No.: 226 Region Association: None |
rktmn247 |
Jan 27 2021, 08:39 PM
Irish Green with GT envy! Group: Members Posts: 347 Joined: 18-August 05 From: Mililani, HI Member No.: 4,612 Region Association: None |
Welcome X-factory! Glad to see you posting here. I have followed your posts on pelican and am really looking forward to this build.
Shivers |
Jan 27 2021, 09:05 PM
Senior Member Group: Members Posts: 2,347 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
42mm, big for a 1911, really curious to see how it will run when it's done.
TRS63 |
Jan 28 2021, 02:51 AM
Member Group: Members Posts: 313 Joined: 14-September 20 From: Germany - Stuttgart Member No.: 24,690 Region Association: Europe |
That is really interesting, as this is exactly the way I have in mind for mine! Keep us updated!
Antoine |
Mark Henry |
Jan 28 2021, 07:21 AM
Stay tuned as parts for the build are arriving daily regards, al Those TB's are awfully tall and you still have to add some kind of air filter. You will lose the raintray so you might want rainhats, you dont want this sticking out the lid. Not trying to be a Debbie downer, just saying you need to trial fit the TB assembly in your 914. I can tell you right now that it will not fit a VW beetle T4 conversion, my ITB set up barely fit in my bug. |
barefoot |
Jan 28 2021, 08:00 AM
Senior Member Group: Members Posts: 1,269 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Mark Henry |
Jan 28 2021, 10:26 AM
42mm, big for a 1911, really curious to see how it will run when it's done. For carb's yes, for FI should not matter at all as fuel delivery is independent of throat size. Yes...but...too big and you make vacuum issues worse, add a big duration cam and you're running in alphaN/TPS only. |
JamesM |
Jan 28 2021, 10:48 AM
42mm, big for a 1911, really curious to see how it will run when it's done. For carb's yes, for FI should not matter at all as fuel delivery is independent of throat size. Yes...but...too big and you make vacuum issues worse, add a big duration cam and you're running in alphaN/TPS only. (IMG:style_emoticons/default/agree.gif) Might as well cam the hell out of it as you are most likely going to have very little resolution with the vacuum signal and have to run alphaN anyways Ran 42mm Jenveys on a 2270 with a cam optimized for lower RPM/very good vacuum and was still seeing 0 vacuum at roughly 30% throttle off idle . They were a pretty good match for that motor, running in MS hybrid mode split the map almost 50/50. Running on a 1911 I wouldn't be surprised if you wind up seeing no vacuum across 70%+ of operating conditions. |
Lo-Fi Version | Time is now: 25th April 2024 - 12:00 PM |
