UPDATE: Rubber Trailing Arm Bushings Group Buy, Order placed - group buy closed |
bdstone914 |
Jan 29 2021, 04:51 PM
bdstone914 Group: Members Posts: 4,517 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Update: 3/9/2021
Bushings are paid for and will be hipped from RD Canada soon. It looks like RD Canada will be adding these to their line soon. I convinced them there is a demand for the rubber bushings with Elephant racing as the only other supplier currently offering them. I have a jig made up that I think will allow the installation of the bushings without a shop press. I will start a new thread with the details and progress.regress on it. If it works I can lend it out and will share the parts source info. It basically uses a piece of 10mm all thread to pull the shaft through while clamping on the bushings so they do not get pulled into the trailing arm. Bushings were brought in to Restoration Designs Canada. I will be placing the order as soon as all are paid up. Will send PM's to all who have inquired. Last chance to get in on the group buy. @914werke @djway @Superhawk996 @sportlicherFahrer @Monteral914 @racer914 Shipping will be about $7 per set if ten sets are ordered. We are at ten sets now if everyone who has replied comes through. Reshipping will be $8. I prefer Venmo as form of payment as I am doing this at cost. If you are computer challenged I can take a check. Cost total for softer bushings is $100 and $110 for the harder bushings. If you want two or more sets deduct $8 from cost of the second set. Please email me at bdstone914 at AOL dot com with you full name, address, number of sets wanted and hardness. I am going to order at least one set of real rubber trailing arm bushings from Restoration Designs Europe. They offer a street grade and a stiffer performance grade. The only other source for rubber trailing arm bushings I know of is Elephant Racing and they are very expensive. I have requested a quote for shipping on up to 10 sets. The current prices are 69 for the street version and 77 Euros for the performance version. Rubber bushing are difficult to install but are like the original bushings that add torsional rigidity and adapt to the trailing arm variations. I am going to get one set of each. The biggest problem I had installing the rubber bushing is that the bushing wanted to push out or scrunch up as the shaft was inserd. I suspect the stiffer bushing may be easier to install. Here are the links: https://www.restoration-design.eu/silent-bl...-set-4-pcs.html https://www.restoration-design.eu/silent-bl...-pcs-10646.html |
Montreal914 |
Jan 31 2021, 11:40 AM
Senior Member Group: Members Posts: 1,548 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
I have a set of 914Rubber compliant rubber bushings (or what ever they are) that I got in the group buy, but If I am to have potential issues down the road, I am interested in your rubber bushings from Restoration Design EU Bruce. I am definitely in for a turn key solution too, i.e. I bring you the rebuilt/re-plated bushingless arms and shaft I got from you a while back, and you press in the rubber bushings ready for the arms to be bolted on... (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/smilie_pokal.gif) |
bdstone914 |
Feb 1 2021, 07:43 PM
(IMG:style_emoticons/default/popcorn[1].gif) I have a set of 914Rubber compliant rubber bushings (or what ever they are) that I got in the group buy, but If I am to have potential issues down the road, I am interested in your rubber bushings from Restoration Design EU Bruce. I am definitely in for a turn key solution too, i.e. I bring you the rebuilt/re-plated bushingless arms and shaft I got from you a while back, and you press in the rubber bushings ready for the arms to be bolted on... (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/smilie_pokal.gif) @Montreal914 Sounds like a plan. I have a set of arms that need bushings. If you want the hard bushing I will install the softer ones in the arms I have. Saves me getting another sets of arms powder coated. |
Montreal914 |
Feb 1 2021, 08:19 PM
(IMG:style_emoticons/default/popcorn[1].gif) I have a set of 914Rubber compliant rubber bushings (or what ever they are) that I got in the group buy, but If I am to have potential issues down the road, I am interested in your rubber bushings from Restoration Design EU Bruce. I am definitely in for a turn key solution too, i.e. I bring you the rebuilt/re-plated bushingless arms and shaft I got from you a while back, and you press in the rubber bushings ready for the arms to be bolted on... (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/smilie_pokal.gif) @Montreal914 Sounds like a plan. I have a set of arms that need bushings. If you want the hard bushing I will install the softer ones in the arms I have. Saves me getting another sets of arms powder coated. Here are the parts I got from you (kind of dusty now... (IMG:style_emoticons/default/dry.gif) ). Once you are ready, I can drop these off for the bushing install. (IMG:style_emoticons/default/smash.gif) |
Lo-Fi Version | Time is now: 11th May 2024 - 02:07 PM |
