UPDATE: Rubber Trailing Arm Bushings Group Buy, Order placed - group buy closed |
Montreal914 |
Jan 31 2021, 11:40 AM
Senior Member Group: Members Posts: 1,532 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
I have a set of 914Rubber compliant rubber bushings (or what ever they are) that I got in the group buy, but If I am to have potential issues down the road, I am interested in your rubber bushings from Restoration Design EU Bruce. I am definitely in for a turn key solution too, i.e. I bring you the rebuilt/re-plated bushingless arms and shaft I got from you a while back, and you press in the rubber bushings ready for the arms to be bolted on... (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/smilie_pokal.gif) |
bdstone914 |
Feb 1 2021, 09:52 AM
bdstone914 Group: Members Posts: 4,497 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Bump. See update in initial post.
racer914 |
Feb 1 2021, 11:14 AM
Member Group: Members Posts: 77 Joined: 1-October 19 From: Keystone Heights, FL Member No.: 23,513 Region Association: South East States |
I'm in for a set of the performance grade...I sent an email with info and Venmo for payment. Thanks, Dave
sportlicherFahrer |
Feb 1 2021, 06:35 PM
Nothing to see here. Group: Members Posts: 1,070 Joined: 18-April 05 From: Tacoma, WA Member No.: 3,945 Region Association: Pacific Northwest |
Email sent per updated OP! (IMG:style_emoticons/default/aktion035.gif)
bdstone914 |
Feb 1 2021, 07:43 PM
(IMG:style_emoticons/default/popcorn[1].gif) I have a set of 914Rubber compliant rubber bushings (or what ever they are) that I got in the group buy, but If I am to have potential issues down the road, I am interested in your rubber bushings from Restoration Design EU Bruce. I am definitely in for a turn key solution too, i.e. I bring you the rebuilt/re-plated bushingless arms and shaft I got from you a while back, and you press in the rubber bushings ready for the arms to be bolted on... (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/smilie_pokal.gif) @Montreal914 Sounds like a plan. I have a set of arms that need bushings. If you want the hard bushing I will install the softer ones in the arms I have. Saves me getting another sets of arms powder coated. |
Montreal914 |
Feb 1 2021, 08:19 PM
(IMG:style_emoticons/default/popcorn[1].gif) I have a set of 914Rubber compliant rubber bushings (or what ever they are) that I got in the group buy, but If I am to have potential issues down the road, I am interested in your rubber bushings from Restoration Design EU Bruce. I am definitely in for a turn key solution too, i.e. I bring you the rebuilt/re-plated bushingless arms and shaft I got from you a while back, and you press in the rubber bushings ready for the arms to be bolted on... (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/smilie_pokal.gif) @Montreal914 Sounds like a plan. I have a set of arms that need bushings. If you want the hard bushing I will install the softer ones in the arms I have. Saves me getting another sets of arms powder coated. Here are the parts I got from you (kind of dusty now... (IMG:style_emoticons/default/dry.gif) ). Once you are ready, I can drop these off for the bushing install. (IMG:style_emoticons/default/smash.gif) |
bdstone914 |
Mar 4 2021, 11:12 AM
Bump with update.
MM1 |
Mar 4 2021, 03:19 PM
914 obsession continues Group: Members Posts: 608 Joined: 9-May 18 From: Thousand Oaks, CA Member No.: 22,105 Region Association: Southern California |
I'll take a set of the harder bushings, please.
Montreal914 |
Mar 5 2021, 08:35 PM
@bdstone914 , sending the money via Venmo with my daughter's account. You should receive $110 tonight.
Thank you for organizing this (IMG:style_emoticons/default/smilie_pokal.gif) and sorry for the delay... (IMG:style_emoticons/default/sad.gif) |
Mikey914 |
Mar 7 2021, 12:46 AM
The rubber man Group: Members Posts: 12,625 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
What is the expected difference to 914 Rubber trailing arm bushings? I'd love to know more about the expected differences (dimensions, durometer, or bushing rates) either from street to performance or better yet to all other competitors. I'll need a set but haven't decided on source. You're corect Elephant is very expensive, and more recently I think @bbrock has run into some fittment issues with 914Rubber parts on OEM pivot shafts. I know I definately don't want to do solid stainless pivots and add more weight for no reason. Would love to see something that works with OEM shafts. Than expected difference is that fit and function like the original rubber bushings. They can adapt to the variation in diameter and lack of linearity of the two holes. The 914 Rubber bushings are not made of rubber. There is no compression like the rubber. I want to try both durometers with bith the SS 914 Rubber shafts and non straight original shafts. I expect the 85 durometer bushings will be easier to install as they wil have less tendendancy to scrunch up as the shaft enters from inside the trailing arm. I dont think the performace differen e beyween the street and performance bushing will be noticible. Bruce, news to me the 914Rubber ones are not made of rubber. You may be thinking of the old polygraohite ones. Ours are made of rubber |
bdstone914 |
Mar 7 2021, 08:39 AM
What is the expected difference to 914 Rubber trailing arm bushings? I'd love to know more about the expected differences (dimensions, durometer, or bushing rates) either from street to performance or better yet to all other competitors. I'll need a set but haven't decided on source. You're corect Elephant is very expensive, and more recently I think @bbrock has run into some fittment issues with 914Rubber parts on OEM pivot shafts. I know I definately don't want to do solid stainless pivots and add more weight for no reason. Would love to see something that works with OEM shafts. Than expected difference is that fit and function like the original rubber bushings. They can adapt to the variation in diameter and lack of linearity of the two holes. The 914 Rubber bushings are not made of rubber. There is no compression like the rubber. I want to try both durometers with bith the SS 914 Rubber shafts and non straight original shafts. I expect the 85 durometer bushings will be easier to install as they wil have less tendendancy to scrunch up as the shaft enters from inside the trailing arm. I dont think the performace differen e beyween the street and performance bushing will be noticible. Bruce, news to me the 914Rubber ones are not made of rubber. You may be thinking of the old polygraohite ones. Ours are made of rubber I bought them and they are not rubber like the originals. They are marked WDG. You list the Daystar on the site and yours with not description. They squeak like the poly material. Check them out. |
Mikey914 |
Mar 7 2021, 10:02 AM
The polygraphite will squeak.
The not sure why yours would be ones you used an oil to install them. |
bdstone914 |
Mar 9 2021, 01:10 PM
Bump, order placed. Bushings will be shipped to me soon.
Grego in Sac |
Mar 10 2021, 08:22 PM
Newbie Group: Members Posts: 5 Joined: 6-March 21 From: Northern California Member No.: 25,301 Region Association: Northern California |
Am I still able to buy bushings? Any available?
bdstone914 |
Mar 11 2021, 08:35 AM
Am I still able to buy bushings? Any available? @Grego in saC Sorry but no. Only enough were brought in from Europe to cover pre orders. They should be available from Restoration Designs in Canada as they are adding them to their offering. |
Lo-Fi Version | Time is now: 29th March 2024 - 08:41 AM |
