Converting a 95 3.6 to a 914, Questions questions |
Jgilliam914 |
Feb 5 2021, 01:04 PM
914 Guru Group: Members Posts: 5,327 Joined: 30-July 12 From: Iowa / Florida Member No.: 14,732 Region Association: Upper MidWest |
I’ve had the engine a few years before the air cooled engines went insane. So I am getting it off the shelf to prepare the install. I have purchased the harness adapter from Patrick Motorsports. I also have their air intake conversion. Also their Pulley system. I removed the speed control unit and A/C mounts. My questions are mainly about the electrical and vacuum systems. When I purchased the Engine from LA Dismantler’s they also sent the DME and the engine harness. When I finally got around to digging them out and matching them up to the engine I see a lot of sensor connections that have no mates. My questions are some of these not needed in this application? Or am I missing something? [attachmentid=779 552] |
ClayPerrine |
Feb 5 2021, 01:37 PM
Life's been good to me so far..... Group: Admin Posts: 15,441 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I can tell you from experience...
Picture #1. connections for the engine mounted blower motor. Picture #4. The green plugs go to the knock sensor. the 2 pin plug with the mercedes emblem goes to the resonance flap solenoid, and the big round plug goes to the mass airflow meter. The pictures aren't detailed enough to identify most of the wires. Clay |
Jgilliam914 |
Feb 5 2021, 01:43 PM
I can tell you from experience... Picture #1. connections for the engine mounted blower motor. Picture #4. The green plugs go to the knock sensor. the 2 pin plug with the mercedes emblem goes to the resonance flap solenoid, and the big round plug goes to the mass airflow meter. The pictures aren't detailed enough to identify most of the wires. Clay I can definitely add more!! |
Lo-Fi Version | Time is now: 7th May 2024 - 12:22 AM |
