Converting a 95 3.6 to a 914, Questions questions |
Jgilliam914 |
Feb 5 2021, 01:04 PM
914 Guru Group: Members Posts: 5,327 Joined: 30-July 12 From: Iowa / Florida Member No.: 14,732 Region Association: Upper MidWest |
I’ve had the engine a few years before the air cooled engines went insane. So I am getting it off the shelf to prepare the install. I have purchased the harness adapter from Patrick Motorsports. I also have their air intake conversion. Also their Pulley system. I removed the speed control unit and A/C mounts. My questions are mainly about the electrical and vacuum systems. When I purchased the Engine from LA Dismantler’s they also sent the DME and the engine harness. When I finally got around to digging them out and matching them up to the engine I see a lot of sensor connections that have no mates. My questions are some of these not needed in this application? Or am I missing something? [attachmentid=779 552] |
bahnzai |
Feb 6 2021, 03:51 PM
Member Group: Members Posts: 305 Joined: 26-July 06 From: Columbia, SC Member No.: 6,509 Region Association: South East States |
Clay has ID'd several there. I will add a few pictures to show the connectors plugged on the motor, and a string of connectors not used. Notice the the injector plugs are color coded according to cylinders on each bank.
Left bank injectors right bank injectors plugs not used plugs not used plug not used right side -green knock sensor, white-head temp sensor ignition module |
Lo-Fi Version | Time is now: 6th May 2024 - 11:56 PM |
