Subaru 5 and new 6 speed cable shift info, The new 6 speed split case. |
914Subaru |
Feb 6 2021, 05:27 PM
Member Group: Members Posts: 59 Joined: 19-October 08 From: Duluth, MN Member No.: 9,667 Region Association: Upper MidWest |
The Subaru 5 Speed split case transmission has been around for many years with the later ones have stronger 1st and 2nd gears. They are a linkage shift. I currently have the 5-speed in my 914 and it works flawless.
There are 2 types of Subaru 6 speed transmissions. The Subaru WRX STI about 2004-? and have a one piece case. These are the biggest, strongest and longest transmission. Linkage shift. Arguably more than you need for most 914's because the extra weight and added rotating mass is not needed. Last I looked nobody makes the coupler to disable the AWD and needs to be welded as been shown on 914World. The latest is 6-speed split case cable shift that is the same length as the 5-speed. In the US it comes in the the 2015-? WRX. (not WRX STI) also 2014-17 Forester and probably a couple others. There are different ratios between models but externally and fit appear to be the same. Outside the US they came in diesels also. Subarugears.com sells the coupler and rear cover. The only negative I noticed so far is it doesn't have a speed sensor. I just purchased one out of a 2016 Forester with 43K miles. I will be using the shifter out of the Forester with custom length cables. The Forester transmissions are selling for less than half the price of the WRX. Here are some pictures comparing the 6-speed to an old 5-speed. I think this would be a good option to consider for future swaps. To quickly identify the STI 6-speed I usually look for this divider plate the red arrow points to. |
914Subaru |
Feb 6 2021, 09:10 PM
I haven't driven a 6-speed yet but my thought is if you already have a 5-speed it's not worth the upgrade but if your just starting a project it's worth considering. One advantage is the cable linkage is built into the transmission and you can use the Subaru shift lever. They are newer and easy to find low mile ones. The information I have found so far is first and second gears are wider and stronger than early 5-speeds, 1-4 is the same ratio, 5th is lower and the added 6th gives you lower RPM's at highway speed.
partwerks |
Aug 5 2022, 08:23 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
I haven't driven a 6-speed yet but my thought is if you already have a 5-speed it's not worth the upgrade but if your just starting a project it's worth considering. One advantage is the cable linkage is built into the transmission and you can use the Subaru shift lever. They are newer and easy to find low mile ones. The information I have found so far is first and second gears are wider and stronger than early 5-speeds, 1-4 is the same ratio, 5th is lower and the added 6th gives you lower RPM's at highway speed. Do you have pictures of the shifter? If it doesn't have a speed sensor, is the sensor, and magnet like some setup, another way of doing it? |
Lo-Fi Version | Time is now: 29th April 2024 - 01:59 PM |
