Subaru 5 and new 6 speed cable shift info, The new 6 speed split case. |
914Subaru |
Feb 6 2021, 05:27 PM
Member Group: Members Posts: 59 Joined: 19-October 08 From: Duluth, MN Member No.: 9,667 Region Association: Upper MidWest |
The Subaru 5 Speed split case transmission has been around for many years with the later ones have stronger 1st and 2nd gears. They are a linkage shift. I currently have the 5-speed in my 914 and it works flawless.
There are 2 types of Subaru 6 speed transmissions. The Subaru WRX STI about 2004-? and have a one piece case. These are the biggest, strongest and longest transmission. Linkage shift. Arguably more than you need for most 914's because the extra weight and added rotating mass is not needed. Last I looked nobody makes the coupler to disable the AWD and needs to be welded as been shown on 914World. The latest is 6-speed split case cable shift that is the same length as the 5-speed. In the US it comes in the the 2015-? WRX. (not WRX STI) also 2014-17 Forester and probably a couple others. There are different ratios between models but externally and fit appear to be the same. Outside the US they came in diesels also. Subarugears.com sells the coupler and rear cover. The only negative I noticed so far is it doesn't have a speed sensor. I just purchased one out of a 2016 Forester with 43K miles. I will be using the shifter out of the Forester with custom length cables. The Forester transmissions are selling for less than half the price of the WRX. Here are some pictures comparing the 6-speed to an old 5-speed. I think this would be a good option to consider for future swaps. To quickly identify the STI 6-speed I usually look for this divider plate the red arrow points to. |
Amenson |
Apr 27 2021, 03:29 PM
That's opposite lock!! Group: Members Posts: 645 Joined: 27-May 05 From: Dublin, OH Member No.: 4,154 Region Association: None |
From what I can find online the difference is the final drive.
WRX is 4.11 Forrester is 4.44 With the engine you are building Doug...you definitely don't want the 4.44. |
partwerks |
Aug 5 2022, 08:25 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
76-914 |
Aug 6 2022, 08:08 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
From what I can find online the difference is the final drive. WRX is 4.11 Forrester is 4.44 With the engine you are building Doug...you definitely don't want the 4.44. Which is better for lower rpm's in the road gear? Given the 2 choices from above, the 4.11 would be. If your going 5 speed there are several 3.9 final drive transmissions and two 3.6. Here is a shopping list. https://www.rallispec.com/downloads/Transmi...hart_Public.pdf |
partwerks |
Oct 27 2022, 08:26 PM
From what I can find online the difference is the final drive. WRX is 4.11 Forrester is 4.44 With the engine you are building Doug...you definitely don't want the 4.44. Which is better for lower rpm's in the road gear? Given the 2 choices from above, the 4.11 would be. If your going 5 speed there are several 3.9 final drive transmissions and two 3.6. Here is a shopping list. https://www.rallispec.com/downloads/Transmi...hart_Public.pdf I didn't see any with the 3.6 final drive? |
76-914 |
Oct 29 2022, 07:13 PM
From what I can find online the difference is the final drive. WRX is 4.11 Forrester is 4.44 With the engine you are building Doug...you definitely don't want the 4.44. Which is better for lower rpm's in the road gear? Given the 2 choices from above, the 4.11 would be. If your going 5 speed there are several 3.9 final drive transmissions and two 3.6. Here is a shopping list. https://www.rallispec.com/downloads/Transmi...hart_Public.pdf I didn't see any with the 3.6 final drive? They are 3.7 not 3.6. Probably about 2mph difference at 3300 rpm. There is a calculator on this site that will show you the engine rpm at "X" mph using whatever tire size you are running. I think once you see the minor difference you will not be so concerned with the difference. Which TY model number were you looking at that is a push style rather than the pull style? |
Lo-Fi Version | Time is now: 29th April 2024 - 03:18 PM |
