Subaru 5 and new 6 speed cable shift info, The new 6 speed split case. |
914Subaru |
Feb 6 2021, 05:27 PM
Member Group: Members Posts: 59 Joined: 19-October 08 From: Duluth, MN Member No.: 9,667 Region Association: Upper MidWest |
The Subaru 5 Speed split case transmission has been around for many years with the later ones have stronger 1st and 2nd gears. They are a linkage shift. I currently have the 5-speed in my 914 and it works flawless.
There are 2 types of Subaru 6 speed transmissions. The Subaru WRX STI about 2004-? and have a one piece case. These are the biggest, strongest and longest transmission. Linkage shift. Arguably more than you need for most 914's because the extra weight and added rotating mass is not needed. Last I looked nobody makes the coupler to disable the AWD and needs to be welded as been shown on 914World. The latest is 6-speed split case cable shift that is the same length as the 5-speed. In the US it comes in the the 2015-? WRX. (not WRX STI) also 2014-17 Forester and probably a couple others. There are different ratios between models but externally and fit appear to be the same. Outside the US they came in diesels also. Subarugears.com sells the coupler and rear cover. The only negative I noticed so far is it doesn't have a speed sensor. I just purchased one out of a 2016 Forester with 43K miles. I will be using the shifter out of the Forester with custom length cables. The Forester transmissions are selling for less than half the price of the WRX. Here are some pictures comparing the 6-speed to an old 5-speed. I think this would be a good option to consider for future swaps. To quickly identify the STI 6-speed I usually look for this divider plate the red arrow points to. |
jeff |
Apr 10 2022, 09:25 AM
Member Group: Members Posts: 252 Joined: 17-January 04 From: thousand oaks,ca Member No.: 1,570 |
How difficult would this be to put behind a type iv or a Porsche 6 ? I think some of the Subaru transmissions have pull clutch levers ,some have push levers. Flywheel,clutch and starter differences. Do people swap out the pedal assembles for hydraulic clutch types?
eric914 |
Oct 30 2022, 09:00 AM
Member Group: Members Posts: 381 Joined: 28-January 04 From: Waynesville OH Member No.: 1,613 Region Association: Upper MidWest |
How difficult would this be to put behind a type iv or a Porsche 6 ? I think some of the Subaru transmissions have pull clutch levers ,some have push levers. Flywheel,clutch and starter differences. Do people swap out the pedal assembles for hydraulic clutch types? I had the same thought. I have a 3.2 6 in my car and fear really pushing it. Years ago, I started down the Suby conversion path and still have a 1998 JDM 2L WRX motor with a Kennedy engineered products motor adaptor plate and clutch sitting in the corner of the garage. I wonder if the 914 clutch disk would fit in the Suby clutch assembly? |
76-914 |
Oct 30 2022, 02:17 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
How difficult would this be to put behind a type iv or a Porsche 6 ? I think some of the Subaru transmissions have pull clutch levers ,some have push levers. Flywheel,clutch and starter differences. Do people swap out the pedal assembles for hydraulic clutch types? I had the same thought. I have a 3.2 6 in my car and fear really pushing it. Years ago, I started down the Suby conversion path and still have a 1998 JDM 2L WRX motor with a Kennedy engineered products motor adaptor plate and clutch sitting in the corner of the garage. I wonder if the 914 clutch disk would fit in the Suby clutch assembly? Some people do switch out pedal assemblies but it isn't necessary. You can easily convert your 914 pedal cluster to hydraulic. You will use the old clutch tube as the conduit for the AN-3 hydraulic hose. Conversely you can convert the old cable system to work with a Subaru transmission. I don't recommend this as it is more difficult than converting to hydraulic and you are left with the problematic cable or clutch tube weld failing. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 29th April 2024 - 05:53 PM |
