partwerks |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,613 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 ![]() |
For sale: Parts lot
All used parts. Cash if local pickup, or paypal if being shipped. Shipping on top of stated price. 1. Relay board-came off of a running car, but has been sitting out in the elements for about 3 months, but very little moisture during those months. $42.00 2. Front hood hinges & springs-$41.00 3. Rear deck lid hinges-$20.00 4. Trunk torsion bars & clamps-$25.00 5. Window crank-$1.00 6. Hood release cable (no plastic tube) $25.00 7. Trunk light-$5.00 8. Relay board cover-has cut/crack on top, and a piece of corner broke off-$1.00 Knob, and bolt are SOLD. 9. Battery hold down clamp-$2.00 10. Front targa latches-one has a good handle, but bent hook, and the other one has a cracked handle, but good hook. Can make one good handle out of them both. $18.00 11. Front lower hood latch-$31.00 12. Used 200# springs-$40.00-SOLD 13. Dog bones, two-$10.00-SOLD 14. Clutch stop-$4.00-SOLD 15. Fuse box-$9.00 16. Fresh air vent tube grommets (pair) $5.00 17. Brake reservoir-$4.00-SOLD 18. Tripometer cable-$15.00-SOLD 19. Window channel sealing rails-one rail has two holes that are over sized-$15.00-Sold 20. Driver side vertical rollbar pad-$10.00-SOLD 21. Glove box locks (2) A bit rough around the front. One is complete, the other isn't-$20.00-Sold 22. Trans ground cable-$2.00-SOLD 23. Windshield pillar pads-has some material missing in the corners-$30.00-SOLD 24. L defroster duct-has inner tab broken off-$10.00 25. Control box pieces-Control box has some metal bracket parts broken off sides. Otherwise all have the tabs intact-$22.00 26. Clutch cable bracket w/bushing-$5.00 27. Clutch cable clevis-$5.00-SOLD 28. Pedal board hold down clamp (Pyramid shaped) $1.00-SOLD 29. Fuel pump bracket-$5.00-SOLD 30. After market rear swaybar-$50.00-SOLD 31. Steering column. Missing small screws for ignition switch retainer bezel around ignition lock on the front. No key. $114.00 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Literati914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,016 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region ![]() |
I'm interested in the aftermarket rear sway bar - can you get me shipping to 75233? THX.
frostyf |
Member ![]() ![]() Group: Members Posts: 155 Joined: 27-March 14 From: VA 23455 Member No.: 17,168 Region Association: MidAtlantic Region ![]() ![]() |
Couldn't see the a frame pads:
![]() And keen to get the 20. Driver side vertical rollbar pad-$10.00 Can I go 2nd for the rear sway bar if literati passes? 30. After market rear swaybar-$50.00 Thanks, Nick PS Shipping to VA 23455 |
ndfrigi |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,967 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California ![]() ![]() |
edited: since someone already ahead of me for #23
interested with #18 and 27. quote shipping to 90680. thank you! |
partwerks |
Literati914 |
.. besides the rear sway bar(30), I'd also like the fuel pump bracket(29) - thx.
partwerks |
partwerks |
Couldn't see the a frame pads: ![]() And keen to get the 20. Driver side vertical rollbar pad-$10.00 Can I go 2nd for the rear sway bar if literati passes? 30. After market rear swaybar-$50.00 Thanks, Nick PS Shipping to VA 23455 I swapped out one picture for a close up of the WS pad. It's the last picture. |
cork |
ground zero ![]() Group: Members Posts: 49 Joined: 11-January 03 From: phoenix,az Member No.: 132 ![]() |
i'll take the ground strap and dog bones, please send PayPal info Thanks
partwerks |
Bump
StarBear |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States ![]() ![]() |
I’ll take #8 cover with post and knob. Will pm with address and zip.
partwerks |
Bump
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,439 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Just a note to whomever bought the rear sway bar. The aftermarket bar in the picture will not fit the stock factory sway bar mounts. I recently bought one just like it and found this out the hard way.
Clay |
B2524 |
It's a sickness. ![]() ![]() Group: Members Posts: 72 Joined: 12-November 11 From: Outside Paso Robles CA Member No.: 13,776 Region Association: Northern California ![]() |
Ill take the 200lbs springs
PM PP info and total Ships to 93465 |
rgb91424 |
Newbie ![]() Group: Members Posts: 20 Joined: 12-March 06 From: Kingman Az Member No.: 5,709 ![]() |
I would like the clutch stop for pedal board #14 and the pedal board retainer #28
I don't do pay pal. How about USPS money order ? Shipping would be to 86401 Az. Thanks Bob B. |
partwerks |
Bump
partwerks |
Bump
partwerks |
Bump
mgp4591 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,702 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region ![]() ![]() |
PM sent.
56kabrio |
Member ![]() ![]() Group: Members Posts: 65 Joined: 1-December 05 From: Framingham, MA Member No.: 5,219 Region Association: None ![]() ![]() |
Lo-Fi Version | Time is now: 11th July 2025 - 02:04 AM |
