914-6 GT front hood prop rod install |
raynekat |
Feb 7 2021, 09:57 PM
Advanced Member Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
It's been a few months since I installed my PMB Performance 914-6 GT front hood prop rod.
Thought I'd share as it's a very slick replica of the original and a "must have" in my mind for those that have lightweight hoods. Here's the installed product in my car: When not in use, the springs allow the prop rod to rotate up and out of the way against the underside of the hood. Pretty slick I'd say. Those Porsche race engineers..... In my application, I was unable to land the bottom of the prop rod on the backside of the fuel tank wall because the flange on the fuel tank interfered. So I instead I had my prop rod land on the frontside with the help of a very small catchment clip....just something I had laying around in my box of junk that seemed to be about the right size. For my installation, I modified some of the installation methods/hardware as my very thin supports on the backside of my Getty hoods would not allow use of the supplied nutserts. Instead I used an appropriately sized bolt and nut. I just happened to have a rubber grommet that was the perfect size to put on the perimeter of the bolt head.....it fits very snuggly. It acts as a buffer between the prop rod mount and the underside of the fiberglass hood. This is a great setup for a lightweight hood prop rod. It is somewhat "delicate" so I wouldn't advise using it in 40mph winds. Or with heavy stock metal hoods. |
pete000 |
Feb 11 2021, 06:28 PM
Senior Member Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
I have mine still in the box, need to order the Getty Lids, Any concerns about not running hood pins for security?
tygaboy |
Feb 11 2021, 07:25 PM
914 Guru Group: Members Posts: 5,300 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
I have mine still in the box, need to order the Getty Lids, Any concerns about not running hood pins for security? (IMG:style_emoticons/default/agree.gif) I just got my Getty lids and am curious about the need for hood pins. I did install the hood with just the factory latch and it "seems" like it wouldn't require pins. It feels pretty solid in the outer corners. That said, I'd like to hear from folks with experience. Thanks. |
Lo-Fi Version | Time is now: 28th May 2024 - 07:03 AM |
