Drop some knowledge: what external faults would prevent an alternator from charging? |
Tdskip |
Feb 10 2021, 01:10 PM
The 1975 is not recharging the battery, so I obviously have either a fault with the alternator or the wiring/charging circuit.
In the interest of being just slightly less of a dope than I currently am, what would cause the charging circuit to fail if it is not an internal alternator issue. In other words, if we assume that the alternator is healthy and there’s no issues with the brushes etc. internal to the alternator wear with the wiring I have gone sideways to result in it not charging? This seems like a useful topic to get into the forum here, thanks in advance for the shared knowledge. |
Mikey914 |
Feb 10 2021, 03:06 PM
The rubber man Group: Members Posts: 12,648 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Also, if your bulb for the alternator doesn't light up when you turn the key (or you have replaced with an LED) it will not get the small charge necessary to excite the field and allow it to charge.
Lo-Fi Version | Time is now: 1st May 2024 - 11:53 AM |
