Drop some knowledge: what external faults would prevent an alternator from charging? |
Tdskip |
Feb 10 2021, 01:10 PM
The 1975 is not recharging the battery, so I obviously have either a fault with the alternator or the wiring/charging circuit.
In the interest of being just slightly less of a dope than I currently am, what would cause the charging circuit to fail if it is not an internal alternator issue. In other words, if we assume that the alternator is healthy and there’s no issues with the brushes etc. internal to the alternator wear with the wiring I have gone sideways to result in it not charging? This seems like a useful topic to get into the forum here, thanks in advance for the shared knowledge. |
Spoke |
Feb 24 2021, 05:41 AM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
You can do a rudimentary test on the alternator that Clay mentioned by removing the VR and shorting the D+ and DF pins on the VR connector on the relay board. Then start the car and measure the battery voltage. It should be around 16V for a good alternator.
Lo-Fi Version | Time is now: 1st May 2024 - 09:25 AM |
