OEM /6 mount, Mad Dog |
930cabman |
Feb 11 2021, 01:39 PM
Advanced Member Group: Members Posts: 3,000 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Making the conversion to a 6 cyl, we have several choices to make with mounts, exhaust, fuel, oil tank, engine tin, ....
I recently purchased the OEM mount from Mad Dog, you couldn't ask for a better fit. It nestled into the recess and allowed basically no room for error. I socked it in with a couple self tapping screws and went ahead with the plug and fillet welds. I removed the paint from the mounting surfaces with paint stripper and cleaned it up with a sanding disc prior to welding From what I understand the factory placed additional reinforcement in this area. Running the welds for this mount I sensed it the way my MIG was acting. I bet you could pick the entire car up from this mount. Very well done Mad Dog |
maddog |
Feb 28 2021, 07:58 AM
Member Group: Members Posts: 200 Joined: 19-May 03 From: Grand Rapids Michigan Member No.: 710 Region Association: None |
Hi guys, Hawk is right about the URO mount interference. I had Luke check his OEM mount fitup and it was the same. Hawk has the best solution for anyone that already has the mount, just get a grinder and put a nice 4-5mm radius on the two edges and the URO mount will drop right in. Dont worry about removing that little bit of material to get the radius because there is a nice fillet weld behind the wall. I did one in my bench vise and it only took minutes like Hawk said.
Lo-Fi Version | Time is now: 28th April 2024 - 12:44 AM |
