Recommendations for torsion bars for 914-6 DE use |
maj75 |
Feb 11 2021, 07:19 PM
Member Group: Members Posts: 69 Joined: 26-May 20 From: Lighthouse Point, FL Member No.: 24,317 Region Association: None |
I’m building a 914 with a 3.0 SC motor. It will be an occasional street car and driven to the track. I do most of my events at Sebring which is rough. Running bilstein struts and 205 tires. Weltmeister sway bar in front. Stock 914 lower control arms, Elephant poly bronze bushings.
How big is too big on the torsion bars. |
mlindner |
Feb 12 2021, 06:03 AM
Senior Member Group: Members Posts: 1,509 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
What size will be the rear springs.
maj75 |
Feb 12 2021, 07:01 AM
Undetermined at this point. Need to see if Koni will rebuild my ‘73 dated shocks and what specs they support.
stownsen914 |
Feb 14 2021, 10:13 AM
Senior Member Group: Members Posts: 912 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
For shock rebuilding, try Koni retailers like Truechoice truechoicekoniracingservices.com
scootergt3 |
Feb 16 2021, 08:52 PM
Newbie Group: Members Posts: 5 Joined: 21-September 13 From: pittsburgh pa Member No.: 16,413 Region Association: None |
I run 22 bars up front and 275 springs in the rear of my race car.
Trekkor |
Mar 12 2021, 09:17 PM
leave them stock.
Build your suspension around them. KT |
Justinp71 |
Mar 26 2021, 03:23 PM
Senior Member Group: Members Posts: 1,582 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
I've had stock torsions and a 19mm sway bar up front for forever with Bilsteins. I recently went to 19mm torsion to stiffen it up some. Really just seat of the pants and driving focus helped me the most, but I just track drive for fun in the 914 not fastest lap. I have seen people run 21mm on the track, but they just seem so stiff for the street.
I've also been running a 3.0 and now a 3.2, 200 or 220lb rear springs. Bilsteins all around. It's always felt balanced atleast on the track. Do yourself a favor and run some weber 40's, headers and DC19 cams if you haven't already. So much fun... |
brant |
Mar 26 2021, 04:41 PM
914 Wizard Group: Members Posts: 11,607 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I used to run 22 and 23 front
But my brake temps came up (in the range I wanted) With 21mm torsions I also dropped my front brake pads 2 notches softer I run a light -6 at 1820lbs And believe the 22 were too stiff I also ron a 29/ or is it 31 front sway bar |
Justinp71 |
Mar 26 2021, 05:37 PM
Also when you go over 20mm in the front and 220lb springs in the back isn't it recommended to have a full cage or you will start twisting the body? |
stownsen914 |
Mar 28 2021, 07:43 AM
campbellcj |
Mar 31 2021, 07:40 AM
I can't Re Member Group: Members Posts: 4,539 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
I have 22s with 300lb or maybe 350 rears, IIRC (been a while). It's stiff to the point most of the spring is in the tire sidewalls, very stable on track or canyons but pretty brutal for just cruising around. Fully caged and reinforced tub which makes a tremendous difference in keeping the tires planted.
zztot |
Apr 19 2021, 09:05 PM
Newbie Group: Members Posts: 4 Joined: 25-February 07 From: Panama City Beach,fL Member No.: 7,565 Region Association: None |
To me the 205 tire will limit how stiff you want to go...also which tire...super sticky or streetable.
I ran stock front torsion bars for years with a 21 mm front sway bar and 180 lb rear springs.....finally bumped up to 19 t bars. Fast forward to big sticky tires then the 22 sway bar and 400 lb springs were needed to make to work. It is a slippery slope. |
mlindner |
May 10 2021, 09:04 AM
I run stock front torsion bar with 19mm sway bar and 180 rear spring and Koni shock from GroundControl. They sell a great rear spring/shock setup. Mark
Lo-Fi Version | Time is now: 20th April 2024 - 12:39 AM |
