What Have I Done, Hello, I'd like to introduce myself |
mteovr |
Feb 16 2021, 04:48 PM
Newbie Group: Members Posts: 4 Joined: 23-January 21 From: Los Angeles, CA Member No.: 25,115 Region Association: Southern California |
Hello 914World -
This is Michael, also known as "That naive guy who bought a Porsche 914 project car to bring back to life while documenting the process on YouTube and HotCars.com." https://www.youtube.com/watch?v=J-3nypC_odI&t=27s https://www.youtube.com/watch?v=J-3nypC_odI I've been lurking here on 914World for about a month since I bought the pile of parts. Happy to find so much knowledge and camaraderie, you've already provided me with optimism and inspiration in spades. As you can see from the video and some of my articles, if you feel inclined to take a look, I clearly need professional help. And I mean both mechanically and psychologically, which is why I'm hoping to rely on the similarly afflicted fans of Porsche's maligned mid-engined masterpiece. All alliteration aside (or not), glad to be here and please stop me if I'm doing something wrong before I hurt myself or others! Thanks |
mteovr |
Feb 17 2021, 10:47 AM
Thanks all for the comments and advice already!
Since I filmed the vid, have done much more internet sleuthing, deduced the extra engine crossbar is for the side-shift conversion, and already planning to have the calipers rebuilt by PMB. Placed a few orders with 914Rubber for interior and bushings and etcs, planning to have the motor and side-shift trans rebuilt by pros, especially as unsure what all is going on in there and absolutely zero records from previous owner. @Charles Freeborn - excellent to learn about European Motorworks, will contact them immediately. My priority is getting the mechanicals sorted balancing between budget and performance as much as possible. Then move on to cosmetics and correctness over time. For the engine rebuild, had been previously debating Brothers VW Machine Shop in Ontario or BajaWorx in Yucca Valley. For transaxle was planning to drive it down to California Motorsports in Havasu. Trying to keep it as local as possible, but do you know where Dr. Evil might be located? @mark04usa - great to know about the shift linkage cover and horn, have ordered new shocks all around, plus mounts, bushings, etc for the rear to get that done before the drivetrain returns. @Jonathan Livesay - already tugged out one of the axles in the vid. That was entirely unexpected, though, you shoulda seen my face! But good advice for the stubs, will get on that ASAP, thank you. @coondog - no, but I'm close to Hesperia and there's someone on Craigslist selling lots of 914 parts there, perhaps this is Vince? In the plans to get in touch. @bbrock - don't like the sound of that, uh oh! @all - the warm welcome helps a lot and please keep the advice coming. I'm an absolute amateur and this will no doubt take much longer and cost much more than expected, so anything and everything that can save me headaches is greatly appreciated. |
bbrock |
Feb 17 2021, 10:55 AM
Ha! I wouldn't lose any sleep. So far the car looks fantastic and if you had major repair work to do, it would already be obvious. My prediction is the worst you are likely to find on that car is maybe a jack point or two to repair or replace (no big deal) and a few spots of rust bubbling under the floor tar that can be treated and sealed before they grow into a larger problem. If it was already bad, I think you'd be seeing some evidence on the bottom side. One other thing from your vid. Those positive battery cables are actually stock. They are the power supplies for the main harness. You are missing the large positive cable with traditional lead clamp from battery to starter. Those mystery cables bolt to the side of the lead clamp via a little terminal block. 914Rubber sells repros of the block. You should be dancing a jig for having a 914 that solid to work on! (IMG:style_emoticons/default/piratenanner.gif) |
mteovr |
Feb 17 2021, 05:42 PM
Ha! I wouldn't lose any sleep. So far the car looks fantastic and if you had major repair work to do, it would already be obvious. My prediction is the worst you are likely to find on that car is maybe a jack point or two to repair or replace (no big deal) and a few spots of rust bubbling under the floor tar that can be treated and sealed before they grow into a larger problem. If it was already bad, I think you'd be seeing some evidence on the bottom side. One other thing from your vid. Those positive battery cables are actually stock. They are the power supplies for the main harness. You are missing the large positive cable with traditional lead clamp from battery to starter. Those mystery cables bolt to the side of the lead clamp via a little terminal block. 914Rubber sells repros of the block. You should be dancing a jig for having a 914 that solid to work on! (IMG:style_emoticons/default/piratenanner.gif) The jack points are obviously hard to show when the car's up on the lift but amazingly, they're all pretty pristine. It's truly wild how some things on the car are in great shape and some aren't. The battery cables and block/clamp unit could very well be in the parts pile somewhere, will have to scour the web for what they actually look like. So far a perfunctory Googling doesn't ring any bells. But can't trust my memory... Also, any advice on a solvent for the floor mat tar? Or just a good scrubbing? @all - I'm keeping every and all suggestions as a list in a spreadsheet, so please, keep 'em coming! |
Lo-Fi Version | Time is now: 18th May 2024 - 02:23 PM |
