Staring down the EFI rabbit hole again, /6 intake design, Which way around for the 964 plenums in a 914? |
Mark Henry |
Feb 17 2021, 10:34 AM
One of the locals fell on some hard times, his plans changed and his 930 was sold, so he offered me a smoking deal on an EFI system.
SDS EM5-F /6 system with twin plug coil packs, Siemens 55lb injectors, cold start valve, crank trigger and /6 trigger mount, extra relay outputs (had meth injection), Beru plug wires X2, manuals, base maps, dizzy hole block off, Bosch one wire (Djet) head temp sender plus all the cabling, fuses, etc that are not included with an SDS system. I already have a Wabro 300hp FI pump, a Djet fuel pressure regulator, 14point7 wideband O2 meter and an O2 bung in both headers. This is not a discussion on which Aftermarket EFI system is better, etc but rather on plenum based intake design. I'm not new. I've been playing with a SDS EM4-F /4 system since 2003-2004 that's now on my '67 bug T4 2600cc conversion, I know that ITB's are better for peak HP, but I'm after overall improvement, usable vacuum signal for MAP, drivability, fuel economy and etc. FYI I have also asked this on the bird board here for some more info on the build. This thread shows my /6 conversion a few years back and has all the engine specs here. Plus I've built my own motorcycle ITB's before here. Please I only want to discuss a single TB plenum based intake for performance EFI. |
Mark Henry |
Mar 16 2021, 06:45 AM
My 964 intake halves arrived last night.
I have to figure out the the stubs and center section details, might take a while as I'm super busy restoring 2.0 Djet engines plus other projects this spring/summer. We'll see how much energy I have left over on the weekends. The SDS EFI install itself only takes a weekend, it's the crank trigger and intake fabrication that sucks up the time. I could buy off the shelf... but where's the fun in that? (IMG:style_emoticons/default/biggrin.gif) Attached thumbnail(s) |
ClayPerrine |
Mar 16 2021, 06:49 AM
Life's been good to me so far..... Group: Admin Posts: 15,470 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
My 964 intake halves arrived last night. I have to figure out the the stubs and center section details, might take a while as I'm super busy restoring 2.0 Djet engines plus other projects this spring/summer. We'll see how much energy I have left over on the weekends. The SDS EFI install itself only takes a weekend, it's the crank trigger and intake that sucks up the time. I could buy off the shelf... but where's the fun in that? (IMG:style_emoticons/default/biggrin.gif) Do you need the stubs, injectors and fuel rails? I have 2 spare sets. I actually pulled out a set for you when I was looking for the manifolds. Clay |
Mark Henry |
Mar 16 2021, 07:05 AM
Do you need the stubs, injectors and fuel rails? I have 2 spare sets. I actually pulled out a set for you when I was looking for the manifolds. Clay Hi Clay (IMG:style_emoticons/default/smile.gif) Thank you, yes I'll take them, I'll PM you my contact details. I don't really need the injectors as I have the almost new set that came with my EFI system. |
Lo-Fi Version | Time is now: 18th May 2024 - 10:51 PM |
