flmont |
Senior Member ![]() ![]() ![]() Group: Members Posts: 853 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region ![]() ![]() |
I cant find a smaller Air intake,So I cant install my EG33 without cutting the Bulkhead,.I need about a 1.5" inboard and I then intend to use the Maddog -6 mount and bolt to the bulkhead,.Is this a reasonable path to take I've tried pounding in the bulkhead...its just not deep enoungh.
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,261 Joined: 30-December 02 From: Duluth MN. Member No.: 43 Region Association: Northstar Region ![]() ![]() |
I would try to move it back first. (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) more photos would help.
If you have to move it forward here is what I did. I went back 2" first by relocating the transaxle mounts then rebuilt the forward bulkhead/firewall. http://www.914world.com/bbs2/index.php?sho...ic=7725&hl= |
Superhawk996 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,509 Joined: 25-August 18 From: The Motor City Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
I think I see the problem. . . . wrong engine in the car. (IMG:style_emoticons/default/happy11.gif)
tygaboy |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,460 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California ![]() ![]() |
Couldn't you slice the snorkel off the side of that air box and modify it (or make something else) so it comes out the top then heads rearwards and lives under the engine lid grill? It'd put your intake in a better place to pick up cold air.
Just my $.02,but if you can cut up your bulkhead, I'm betting you'd be able to fab up something that solves this issue. There are also these cobra head elbows that could maybe help? https://www.intakehoses.com/cobra-head-elbows.html Attached thumbnail(s) ![]() |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,653 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Frank, I sent you a PM. Kent
mgp4591 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,313 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region ![]() ![]() |
I cant find a smaller Air intake,So I cant install my EG33 without cutting the Bulkhead,.I need about a 1.5" inboard and I then intend to use the Maddog -6 mount and bolt to the bulkhead,.Is this a reasonable path to take I've tried pounding in the bulkhead...its just not deep enoungh. ![]() How far back does Chris H have his engine? I know he's using a cradle but there's gotta be a way that you can move things around. How are your axles lining up? |
Chris914n6 |
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 2,667 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region ![]() |
2 180* mandrel bends or silicone hoses and relocate the box over the engine.
I'd move the engine back an inch or two before I'd cut firewall. The axles don't need to line up vertically. The CV angles just need to stay in spec during full susp travel. V8 swaps move the trans back 1.5". My Nissan swap moved the trans forward 1.5". Not a problem. |
Literati914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 615 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region ![]() |
I have the same engine (though it needs some essential pieces to make complete/considering parting it). The intake can be turned around, to put the snorkel on the other end, have you considered that? . |
mgp4591 |
(IMG:style_emoticons/default/popcorn[1].gif) I have the same engine (though it needs some essential pieces to make complete/considering parting it). The intake can be turned around, to put the snorkel on the other end, have you considered that? . Then you end up cutting the rear bulkhead going into the trunk. That's why Frank turned around the upper manifold to begin with so there's no cutting involved. |
914forme |
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,856 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None ![]() ![]() |
If you have to cut it to make it work, flip it to the passenger side, cut it there, and put the filter over there where the battery traditionally goes.
Then if you need to add a bit of sheet metal to the area, you can, and it only gets into your passengers seating area. I need my seat all the way back in my 914s. My passengers are normally compact than I. You could also cut the tube and use a silicone tube to fit and then make your transition to the Air tube. Or fabricate an new TB opening duct, and make it fit a bit better. Another option is cut a notch in the duct and plastic weld a notch in it. Or find a section of plastic tube from another intake that goes oolong to allow the same area of airflow to pass thru, and plastic weld it up and in. This is after the MAF so it will need to be sealed. For east=y no car cutting method you can do at home. I thought about making one out of carbon or fiberglass fiber prepreg tape. make the piece out of foam, wrap it in plastic tape, wrap the prepreg around my now buck, and you can clean it up if you want or leave it. Pretty easy and comes in all sorts of neon colors or white if you want. Example skip past the intro but you get an idea of how you can use this to your advantage. Use foam as it is easier than doing this in metal tubing and then doing like they did in the video. Foam you can jut bust it out in pieces to get it out of the tube. |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 11,880 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
You could always take the manifold off and machine off a little bit of the throttle body mounting flange. From the looks of it in that picture, that would give you the clearance you need.
Clay |
flmont |
Tygaboy..Iam trying to post a Pic of my inlet tube..for some reason It wont post,..Yet,.BUt I have about 4 hoses Iam susppose to connect to it and Iam not sure which ones I need or dont need ..Thats why I want to use stock parts for now if I can,.
MGP4591 ChrisH,..used a subaru transmisson Iam using the 901,.From Kent (Still thanking Kent for that generous sale). Chris914N6,..I have heard that is ok to do and I may very well end up doung that,.Iam just very stubboran about that,.simply because I dont really know how to set that up,.I do have the Hyb.Renegades tranny blocks but seem's a little wonkie to install a tranny that way ( iam sure Iam wrong ) I may very well mis understand how Iam suppose to do it ! As soon as I figure out why I cant post pics..I will add them ASAP Thanks Guy's really Appreciate the advise ! Frank |
Chris H. |
don't reMember ![]() ![]() ![]() ![]() Group: Members Posts: 3,767 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest ![]() |
I'm running mine flipped the other way. It's a tight fit but works better on that side. You do have to move the battery somewhere else.
This guy made some pretty major mods to his intake: SVX Samba 1 This guy shaved his down a bit and shortened the rubber tubes that connect to the throttle body (see page 2). I did this as well but not as much. Just remember you only have ONE shot if you do this so be conservative. Shaved EG33 throttle body BTW you do need to use all 4 hoses connected to the intake. 2 are connected to the heads for pressure balancing, the other two are for the IAC valve/warmup circuit. Here's a pic of a really cool custom intake...if only I had the welding skills. ![]() |
flmont |
Thanks Chris H....I thought about doing that then fiber glassing the back, But, I always thought that the intake was built that way for the max air volume So I was afraid to cut into it incase the engine would not run correctly be cause it wasn't getting the correct amount of air flow at WOT,..if you guys think there's no problem with that then,.I'll wack the back off that intake..LOL
flmont |
and yes Clay maybe I could get a little bit more if I get it machined..
flmont |
Literati914...what parts are you missing ?
Chris H. |
Thanks Chris H....I thought about doing that then fiber glassing the back, But, I always thought that the intake was built that way for the max air volume So I was afraid to cut into it incase the engine would not run correctly be cause it wasn't getting the correct amount of air flow at WOT,..if you guys think there's no problem with that then,.I'll wack the back off that intake..LOL Either whack the back off or look at the second link in my post for the other method. Basically what Clay was saying, you trim the throttle body and the snorkel tubes rather than the back. Wouldn't worry about max air flow too much, the Vanagon guys alter their intakes or use smaller ones pretty regularly. |
914forme |
Here's a pic of a really cool custom intake...if only I had the welding skills. ![]() Turbo setup, flow will be a bit whack. Get yourself a plastic welder and be done. Easier to fix plastic than it is to machine an intake or throttle bodies for you at home. But I guess you can do your first year of apprenticeship like my Father in-law did in Germany to become a machinist. Year One you did everything with a hand file, and learned how each metal reacted. |
Chris H. |
Yeah the main pipe would need to be fatter but the design is cool. Rocky Mountain Westy made a nice intake but it was $350. I don’t think they are making it any more.
RMW intake |
Literati914 |
Lo-Fi Version | Time is now: 4th March 2021 - 04:07 AM |
