I guess Iam cutting it..., EG33 Install |
flmont |
Feb 20 2021, 10:43 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
I cant find a smaller Air intake,So I cant install my EG33 without cutting the Bulkhead,.I need about a 1.5" inboard and I then intend to use the Maddog -6 mount and bolt to the bulkhead,.Is this a reasonable path to take I've tried pounding in the bulkhead...its just not deep enoungh.
Chris H. |
Feb 22 2021, 03:43 PM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
I'm running mine flipped the other way. It's a tight fit but works better on that side. You do have to move the battery somewhere else.
This guy made some pretty major mods to his intake: SVX Samba 1 This guy shaved his down a bit and shortened the rubber tubes that connect to the throttle body (see page 2). I did this as well but not as much. Just remember you only have ONE shot if you do this so be conservative. Shaved EG33 throttle body BTW you do need to use all 4 hoses connected to the intake. 2 are connected to the heads for pressure balancing, the other two are for the IAC valve/warmup circuit. Here's a pic of a really cool custom intake...if only I had the welding skills. |
914forme |
Feb 22 2021, 07:31 PM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
Here's a pic of a really cool custom intake...if only I had the welding skills. Turbo setup, flow will be a bit whack. Get yourself a plastic welder and be done. Easier to fix plastic than it is to machine an intake or throttle bodies for you at home. But I guess you can do your first year of apprenticeship like my Father in-law did in Germany to become a machinist. Year One you did everything with a hand file, and learned how each metal reacted. |
Lo-Fi Version | Time is now: 7th May 2024 - 04:16 PM |
