> I guess Iam cutting it..., EG33 Install
flmont
post Feb 20 2021, 10:43 PM
I cant find a smaller Air intake,So I cant install my EG33 without cutting the Bulkhead,.I need about a 1.5" inboard and I then intend to use the Maddog -6 mount and bolt to the bulkhead,.Is this a reasonable path to take I've tried pounding in the bulkhead...its just not deep enoungh.Attached Image
flmont
post Feb 27 2021, 12:17 PM
Well,Thank You,!! How long has that been installed that way and what kind of axles are you using,.?
flmont   I guess Iam cutting it...   Feb 20 2021, 10:43 PM
rick 918-S   I would try to move it back first. :ttiwwp: more p...   Feb 21 2021, 05:32 AM
Superhawk996   I think I see the problem. . . . wrong engine in t...   Feb 21 2021, 09:17 AM
tygaboy   Couldn't you slice the snorkel off the side of...   Feb 21 2021, 09:19 AM
76-914   Frank, I sent you a PM. Kent   Feb 21 2021, 09:43 AM
mgp4591   I cant find a smaller Air intake,So I cant instal...   Feb 21 2021, 10:53 AM
Chris914n6   2 180* mandrel bends or silicone hoses and relocat...   Feb 21 2021, 12:49 PM
Literati914   :popcorn: I have the same engine (though it needs...   Feb 21 2021, 02:58 PM
mgp4591   :popcorn: I have the same engine (though it need...   Feb 21 2021, 03:13 PM
914forme   If you have to cut it to make it work, flip it to ...   Feb 21 2021, 04:59 PM
ClayPerrine   You could always take the manifold off and machine...   Feb 21 2021, 06:32 PM
flmont   Tygaboy..Iam trying to post a Pic of my inlet tube...   Feb 22 2021, 10:16 AM
Chris H.   I'm running mine flipped the other way. It...   Feb 22 2021, 03:43 PM
914forme   Here's a pic of a really cool custom intake....   Feb 22 2021, 07:31 PM
flmont   Thanks Chris H....I thought about doing that then ...   Feb 22 2021, 05:05 PM
Chris H.   Thanks Chris H....I thought about doing that then...   Feb 22 2021, 07:08 PM
flmont   and yes Clay maybe I could get a little bit more i...   Feb 22 2021, 05:07 PM
flmont   Literati914...what parts are you missing ?   Feb 22 2021, 05:48 PM
Chris H.   Yeah the main pipe would need to be fatter but the...   Feb 22 2021, 08:09 PM
Literati914   Literati914...what parts are you missing ? Well...   Feb 23 2021, 12:19 AM
Chris914n6   Happened to have the wheel off and thought of you....   Feb 24 2021, 02:24 PM
flmont   Well,Thank You,!! How long has that been...   Feb 27 2021, 12:17 PM
Chris914n6   ^^ 20 years and stock axles. And 200hp :) If you ...   Feb 27 2021, 08:27 PM
flmont   WOW..and never a issue with them .Thats Great to k...   Feb 27 2021, 11:55 PM
flmont   Iam trying to load a pic of my new intake that I h...   Oct 9 2021, 11:30 AM
SirAndy   Iam trying to load a pic of my new intake that I ...   Oct 9 2021, 11:43 AM
flmont   ok.Thank You,.! Frank   Oct 9 2021, 02:07 PM
flmont   RE: I guess Iam cutting it...   Oct 9 2021, 05:39 PM
flmont   this is the new intake, smaller than stk but not b...   Oct 9 2021, 05:57 PM
flmont   This solves a lot of issues if it works as in...   Oct 9 2021, 09:17 PM
Chris H.   That’ll work great Frank. Is that from Rocky Mou...   Oct 10 2021, 04:04 PM
flmont   Yes,.. it is from Rocky Mtn westy,.I check that si...   Oct 10 2021, 05:20 PM
- Lo-Fi Version Time is now: 16th April 2024 - 03:35 AM
