> Soot in throttle body, Runs perfectly
oakdalecurtis
post Feb 21 2021, 06:50 PM
Oakdalecurtis
Just curious, have 76 2.0, stock except for Crane Fireball EE, runs flawlessly, just had valves done. I had cleaned the throttle body a few years ago, just noticed, while air cleaner was off, a good layer of soot on throttle plate and inside throttle body. Is this indicative of anything?
Tom_T
post Feb 21 2021, 06:54 PM
TMI....
QUOTE(oakdalecurtis @ Feb 21 2021, 04:50 PM) *
Probably running too rich Curtis.
Check that your aux cold start valve (5th injector) &/or that the other 4 injectors aren't running too rich.
Check the plugs for carbon build-up too.
Cheers! (IMG:style_emoticons/default/beerchug.gif)
Tom
JamesM
post Feb 22 2021, 09:26 PM
QUOTE(oakdalecurtis @ Feb 21 2021, 05:50 PM) *
75-76 cars the crank case vents into the air box just before the throttle plate so oil vapor, blow by gasses, etc are all getting sucked through the throttle body. Cant say for sure if that is what is going on, but I wouldn't expect the throttle plate to clean and shiny on the late cars.
Tom_T
post Feb 23 2021, 01:17 PM
TMI....
QUOTE(JamesM @ Feb 22 2021, 07:26 PM) *
A good point to add to our telecon last night Curtis.
Tom
Mark Henry
post Feb 23 2021, 01:24 PM
that's what I do!
QUOTE(JamesM @ Feb 22 2021, 10:26 PM) *
Weber carbs get what's called "carbon tracing lines" on the butterflies when you have worn throttle shaft bushings.
- Lo-Fi Version Time is now: 4th October 2026 - 10:30 PM
