Soot in throttle body, Runs perfectly |
oakdalecurtis |
Feb 21 2021, 06:50 PM
Oakdalecurtis Group: Members Posts: 1,323 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
Just curious, have 76 2.0, stock except for Crane Fireball EE, runs flawlessly, just had valves done. I had cleaned the throttle body a few years ago, just noticed, while air cleaner was off, a good layer of soot on throttle plate and inside throttle body. Is this indicative of anything?
JamesM |
Feb 22 2021, 09:26 PM
Senior Member Group: Members Posts: 1,891 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Just curious, have 76 2.0, stock except for Crane Fireball EE, runs flawlessly, just had valves done. I had cleaned the throttle body a few years ago, just noticed, while air cleaner was off, a good layer of soot on throttle plate and inside throttle body. Is this indicative of anything? 75-76 cars the crank case vents into the air box just before the throttle plate so oil vapor, blow by gasses, etc are all getting sucked through the throttle body. Cant say for sure if that is what is going on, but I wouldn't expect the throttle plate to clean and shiny on the late cars. |
Mark Henry |
Feb 23 2021, 01:24 PM
Just curious, have 76 2.0, stock except for Crane Fireball EE, runs flawlessly, just had valves done. I had cleaned the throttle body a few years ago, just noticed, while air cleaner was off, a good layer of soot on throttle plate and inside throttle body. Is this indicative of anything? 75-76 cars the crank case vents into the air box just before the throttle plate so oil vapor, blow by gasses, etc are all getting sucked through the throttle body. Cant say for sure if that is what is going on, but I wouldn't expect the throttle plate to clean and shiny on the late cars. Weber carbs get what's called "carbon tracing lines" on the butterflies when you have worn throttle shaft bushings. |
Lo-Fi Version | Time is now: 29th April 2024 - 02:05 PM |
