Intake runner connecting hose, any silicone versions? |
timothy_nd28 |
Feb 21 2021, 11:11 PM
In the process of going thru my 1.8 and replacing rubber pieces inside the engine bay. I feel like that I just did this not that long ago, and the once new rubber connecting hoses on the intake to the plenum are already rock hard and cracking.
I think I have seen pictures of people using silicone couplers, but can't find a source. The intake runner measures way closer to 37mm vs 38mm. I feel the 1.5" couple will cause vacuum leaks. Silicone may seem like the way to go, just need a direction what people are using and where to obtain them. |
914Sixer |
Feb 22 2021, 07:31 AM
You are correct, 1.8 do not like vacuum leaks.
jd74914 |
Feb 22 2021, 11:24 AM
I could never find a silicone tube that I liked the fit.
Not what you asked, but when I was DDing my 1.8L in college I replaced those boots with high temp, heavy wall heat shrink tubing from work (Spencer Turbine stuff, most typically used for plant vacuum tubing). Worked great and cleaner look! I'd grab a picture, but engine is disassembled. |
Rand |
Feb 22 2021, 02:01 PM
Seems like a place like this would have something:
https://www.siliconehose.com This has to be awful close: https://www.siliconehose.com/1-380-id-4-ply...ej20-compliant/ |
live free & drive |
Feb 22 2021, 02:05 PM
Member Group: Members Posts: 158 Joined: 29-June 16 From: New Hampshire Member No.: 20,159 Region Association: None |
timothy_nd28 |
Feb 22 2021, 02:59 PM
All good options. I spent some time last night looking for a solution, and that 1.380" silicone hose seemed to be the closest. Thanks Rand, I was on that site the most last night. The intake runner is around 37-38mm, and I wasn't sure how stretchy the 1.38" (35mm) hose would be.
The food grade 37mm silicone hose seems like it will be perfect, not sure if I'm a fan of the transparency. I thought I saw a picture of someones engine bay that already had these and made a bad assumption that some place was selling these as a kit. |
914werke |
Feb 22 2021, 03:15 PM
"I got blisters on me fingers" Group: Members Posts: 10,070 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
This has to be awful close Not like horse shoes (IMG:style_emoticons/default/biggrin.gif) Those hose arent engineered to stretch deflect like rubber hose, needs to be pretty close to the correct ID & typically uses clamps At 4 ply they are pretty firm |
VaccaRabite |
Feb 22 2021, 06:58 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
yeah, stretching silicone hoses is a loosing battle. They are usually nylon reinforced and that stuff does not stretch well.
Though the stock connectors don't use a clamp, you can put a clamp on silicone to make it squish down a little more. For turbo applications you always you a clamp to keep from blowing the boot off under boost. Zach |
914werke |
Feb 22 2021, 07:20 PM
Th OD of s 2.0L tube is approx 1.54", the plenum side is a bit less so the 1.5" stuff would be a better bet
Lo-Fi Version | Time is now: 18th May 2024 - 04:48 PM |
