Best batteries, Road n Track’s opinion |
oakdalecurtis |
Feb 22 2021, 12:04 PM
Oakdalecurtis Group: Members Posts: 1,325 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
Seems like “what’s the best battery for our teeners” always comes up. Here’s Road n Tracks current opinion...
https://www.roadandtrack.com/car-culture/ca...s-from-experts/ |
Morph914 |
Feb 25 2021, 07:28 PM
Member Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States |
I’m about to purchase a battery, so this was helpful. But after looking at the Odyssey’s online, they are smaller than standard. Will I be able to mount these with the stock equipment, or will I have to modify something to make it work?
The PC 680 gives measurements of 7.15” x 3” x 6.65” and 13.45 lbs, the PC 925 gives measurements of 6.44”x 6.75” x 4.88 and 26lbs. I’m leaning towards the PC 925 if it can be mounted without modifications. Does anyone have a picture of a pc 925 mounted in their car? Cheers, John |
horizontally-opposed |
Feb 25 2021, 08:00 PM
Advanced Member Group: Members Posts: 3,431 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
I’m about to purchase a battery, so this was helpful. But after looking at the Odyssey’s online, they are smaller than standard. Will I be able to mount these with the stock equipment, or will I have to modify something to make it work? The PC 680 gives measurements of 7.15” x 3” x 6.65” and 13.45 lbs, the PC 925 gives measurements of 6.44”x 6.75” x 4.88 and 26lbs. I’m leaning towards the PC 925 if it can be mounted without modifications. Does anyone have a picture of a pc 925 mounted in their car? Cheers, John You can fab something up, or buy ready made mounts for $135 without provision for a cut-off or $145 with provision for the cut-off. If you want ready made: https://www.rennline.com/Battery-Mount-Kits/products/169/ Some might know of other leads, but adding one of these mounts closes the gap to an Anti-Gravity H5 a bit more—which doesn't need an adapter. Not sure which way I'll go. |
Lo-Fi Version | Time is now: 9th May 2024 - 07:35 PM |
