seat options with better support and the taller driver, what have those drivers 6 foot plus found? I want a head rest that actually behind not below my head! |
DRPHIL914 |
Feb 23 2021, 07:39 AM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
first off- i am 6'1", the primary use of this seat will be for AX and trips to the mountains, aggressive driving. I want better side support and head protection. right now if i got hit from behind like Clay did my head would be shattering the rear window, so this is not a good scenario. i've been searching forum here looking at what others have used. I have looked at the seats that Stefan at GTS Classics makes, and as i look at those options, it seems the best fit and option might be the one that has a 914 shaped headrest but can be raised and lowered, i think it s the Nurburgring, but recently saw a set a member had made i think were the Watkins Glen, they seem to fit in a 914 nicely but the headrest is fixed in place and does not appear to be taller than stock, So i am looking for options that wont completely break the bank but give great support and fit better for my height and size. I did buy some Corbeau from a member but found they are made for someone 5'8" or smaller and as thin as i am, even narrower. so those are gone and i am researching this time better before i buy. Please post pics if you have them!!! |
Racer |
Feb 23 2021, 01:03 PM
Senior Member Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
One old trick when autocrossing?
Remove seat bottom cushion. Maybe lay a thin towel or just sit on the fiberglass. Get a little more side bolster for your thighs and will drop you down in the car (neck closer to headrest?) Also, while not in spirit of the rules, sometimes changing seats means you change classes (depends who you run with). Maybe make a thinner base cushion from a used one? Two.. seat belt.. Either twist belt before buckling, run a CG lock or the old, put on the belt, then creep the seat up a notch to really tighten the belt. My dad used to have a Sheel seat back in the day for DE/AX when he felt he wanted more support. |
Lo-Fi Version | Time is now: 19th May 2024 - 10:53 AM |
