seat options with better support and the taller driver, what have those drivers 6 foot plus found? I want a head rest that actually behind not below my head! |
DRPHIL914 |
Feb 23 2021, 07:39 AM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
first off- i am 6'1", the primary use of this seat will be for AX and trips to the mountains, aggressive driving. I want better side support and head protection. right now if i got hit from behind like Clay did my head would be shattering the rear window, so this is not a good scenario. i've been searching forum here looking at what others have used. I have looked at the seats that Stefan at GTS Classics makes, and as i look at those options, it seems the best fit and option might be the one that has a 914 shaped headrest but can be raised and lowered, i think it s the Nurburgring, but recently saw a set a member had made i think were the Watkins Glen, they seem to fit in a 914 nicely but the headrest is fixed in place and does not appear to be taller than stock, So i am looking for options that wont completely break the bank but give great support and fit better for my height and size. I did buy some Corbeau from a member but found they are made for someone 5'8" or smaller and as thin as i am, even narrower. so those are gone and i am researching this time better before i buy. Please post pics if you have them!!! |
DRPHIL914 |
Feb 24 2021, 08:19 AM
I bought a bag of them from SMC a while ago. If you can't find your missing ones, PM me with your address and I'll put one in the mail to you. So many variables with seats—which is why the stock 914 seats are impressive, as I have yet to meet someone who doesn't find them comfortable for short and long distances. But complaints about side support are common. Some people love their GTS seats. I had a set, and they didn't work for my body type (6'1, but 32-inch inseam, so pretty short legs and a long torso) whether it came to straight-ahead touring or upper body support in turns—though the the GTS seats located my rear end really well. A pair of vintage Scheels offer superior comfort on short and long drives as well as perfect upper body support—for me. Others will probably find them too narrow, and touring comfort seems to be very subjective as well. Agree on need for headrests, and the Scheel headrests seem fine to me. The GTS win here, as they were oversized—to the point I had them reduced a bit. I found Renegade Hybrid seats to be pretty good for comfort and support years ago, and if there's one thing I have learned with 914 seats, and seats in general, it's that cloth seat centers add both grip and comfort. The cheapest and easiest solution, however? Remove 914 seat cushion and give it a go. You'll get more headrest height and more side support, and a towel or bit of foam will go a long way. I was always curious to try something like that with the backrest, too. 6'2" (and shrinking) here. I've had two different stock seat sets in my car and found both very comfortable. My biggest problem was getting my legs under the steering wheel with the top on. A little smaller in diameter wood Nardi steering wheel took care of that problem. But now the speedo and tach are partially covered by the wheel. As an alternate, making a thinner bottom pad wouldn't be that difficult. Memory foam might be especially comfortable. One old trick when autocrossing? Remove seat bottom cushion. Maybe lay a thin towel or just sit on the fiberglass. Get a little more side bolster for your thighs and will drop you down in the car (neck closer to headrest?) Also, while not in spirit of the rules, sometimes changing seats means you change classes (depends who you run with). Maybe make a thinner base cushion from a used one? Two.. seat belt.. Either twist belt before buckling, run a CG lock or the old, put on the belt, then creep the seat up a notch to really tighten the belt. My dad used to have a Sheel seat back in the day for DE/AX when he felt he wanted more support. i think i do lean toward just a modified stock seat. its hard to find the Sheel seats, and even if you do in bad condition the are $$$, same with the Renegade ones that are now not available new, or the original Recaro ones. Taking the cusion out and just using towel will help and might be a good option for those AX days. I also have the issue with legs hitting the steering wheel. I have a smaller Nardi Italian wheel that gives more leg room but then like you said it blocks the vision of the instruments. I dont really want to get something with out trying it again, and i didnt think about the possiblility of changing the seat not being allowed. I would be doing SCCA Solo around here so i have to check. I can do it in the NOVICE class but i dont know about when i steep up to next class in Stock. Phil |
ClayPerrine |
Feb 24 2021, 08:23 AM
Life's been good to me so far..... Group: Admin Posts: 15,470 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
i think i do lean toward just a modified stock seat. its hard to find the Sheel seats, and even if you do in bad condition the are $$$, same with the Renegade ones that are now not available new, or the original Recaro ones. Taking the cusion out and just using towel will help and might be a good option for those AX days. I also have the issue with legs hitting the steering wheel. I have a smaller Nardi Italian wheel that gives more leg room but then like you said it blocks the vision of the instruments. I dont really want to get something with out trying it again, and i didnt think about the possiblility of changing the seat not being allowed. I would be doing SCCA Solo around here so i have to check. I can do it in the NOVICE class but i dont know about when i steep up to next class in Stock. Phil Phil, JWest Engineering makes a steering eccentric adapter for MOMO wheels. It moves the wheel up so you have more leg room. https://www.jwestengineering.com/Steering-E...apter_p_19.html Not that I need it. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 01:07 PM |
