| DRPHIL914 |
Feb 23 2021, 07:39 AM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,971 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
first off- i am 6'1", the primary use of this seat will be for AX and trips to the mountains, aggressive driving. I want better side support and head protection. right now if i got hit from behind like Clay did my head would be shattering the rear window, so this is not a good scenario. i've been searching forum here looking at what others have used. I have looked at the seats that Stefan at GTS Classics makes, and as i look at those options, it seems the best fit and option might be the one that has a 914 shaped headrest but can be raised and lowered, i think it s the Nurburgring, but recently saw a set a member had made i think were the Watkins Glen, they seem to fit in a 914 nicely but the headrest is fixed in place and does not appear to be taller than stock, So i am looking for options that wont completely break the bank but give great support and fit better for my height and size. I did buy some Corbeau from a member but found they are made for someone 5'8" or smaller and as thin as i am, even narrower. so those are gone and i am researching this time better before i buy. Please post pics if you have them!!! |
DRPHIL914 seat options with better support and the taller driver Feb 23 2021, 07:39 AM
Steve I'm 5'10" and my GTS Lemans seat goes... Feb 23 2021, 09:22 AM
mepstein Unless you are willing to pony up the money for cu... Feb 23 2021, 09:38 AM
DRPHIL914
Unless you are willing to pony up the money for c... Feb 23 2021, 09:47 AM
mepstein Having track seats would also be easier on your go... Feb 23 2021, 10:04 AM
horizontally-opposed So many variables with seats—which is why the st... Feb 23 2021, 10:41 AM
PCH 6'2" (and shrinking) here. I've had t... Feb 23 2021, 12:18 PM
oakdalecurtis
6'2" (and shrinking) here. I've had ... Feb 24 2021, 10:39 AM
Racer One old trick when autocrossing?
Remove seat bot... Feb 23 2021, 01:03 PM
DRPHIL914
I bought a bag of them from SMC a while ago. If y... Feb 24 2021, 08:19 AM
ClayPerrine
i think i do lean toward just a modified stock ... Feb 24 2021, 08:23 AM
DRPHIL914
i think i do lean toward just a modified stock... Feb 24 2021, 08:33 AM
Phil,
JWest Engineering makes a steering eccent... Feb 24 2021, 08:37 AM
Craigers17 Dr. Phil,
I have a pair of GTS Seats that might w... Feb 24 2021, 08:48 AM
DRPHIL914
Dr. Phil,
I have a pair of GTS Seats that might ... Feb 24 2021, 09:08 AM
Craigers17 ....a few more pics......they are also a little du... Feb 24 2021, 08:53 AM
horizontally-opposed ^ This is really appealing.
The factory 914 seat... Feb 24 2021, 08:59 AM
Luke M Have you looked at the Recaro pole position seats?... Feb 24 2021, 09:51 AM
DRPHIL914
Have you looked at the Recaro pole position seats... Feb 24 2021, 12:41 PM
Luke M
[quote name='Luke M' post='2894237' date='Feb 24 ... Feb 24 2021, 12:49 PM
eric9144
Have you looked at the Recaro pole position seats... Feb 24 2021, 10:54 AM
DRPHIL914
[quote name='Luke M' post='2894237' date='Feb 24 ... Feb 24 2021, 12:58 PM
DRPHIL914
Have you looked at the Recaro pole position seat... Feb 25 2021, 11:43 AM
Mark Henry I didn't read all of this but I did the thinne... Feb 24 2021, 02:07 PM
eric9144 @Luke M no back pad at the moment, maybe someday ... Feb 24 2021, 05:13 PM
eric9144
are these Recaro Pole position seats? did you get... Feb 25 2021, 11:56 AM
DRPHIL914
are these Recaro Pole position seats? did you ge... Feb 25 2021, 12:10 PM![]() ![]() |
Lo-Fi Version | Time is now: 18th November 2026 - 03:52 PM |
