Rennshifter with center console and leather boot questions. |
Luke M |
Feb 23 2021, 12:35 PM
Senior Member Group: Members Posts: 1,367 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
So while I wait on some sheet metal to come in I've been working on some interior stuff.
I'm going to run a RennShifter with a center console. I do not like the shifter boot supplied. It looks like a cv joint boot to me. I'm thinking of a leather boot for it. Anyone running the above setup that can post a few pics and where you may have gotten the boot from? TIA, Attached image(s) |
Mark Henry |
Feb 23 2021, 01:10 PM
It is a CV boot (IMG:style_emoticons/default/laugh.gif)
Mark Henry |
Feb 23 2021, 01:15 PM
Just take an old leather boot and the rennshifter to an upholstery shop, tell them to make you something as close as possible.
You want leather, I think the AP shift boot is the only interior 914 item that's real leather. |
Luke M |
Feb 23 2021, 01:21 PM
Just take an old leather boot and the rennshifter to an upholstery shop, tell them to make you something as close as possible. You want leather, I think the AP shift boot is the only interior 914 item that's real leather. I was thinking if there was one from another vehicle that someone retro fitted. I could always take it to an upholstery shop but wanted to see what else was available first. |
Mark Henry |
Feb 23 2021, 01:28 PM
That's quite the dogleg, if it sewn it will likely need something custom for that bend.
I have a Rennshifter as well, so please post your solution when you find it. (IMG:style_emoticons/default/smile.gif) |
Luke M |
Feb 23 2021, 01:36 PM
That's quite the dogleg, if it sewn it will likely need something custom for that bend. I have a Rennshifter as well, so please post your solution when you find it. (IMG:style_emoticons/default/smile.gif) I'll have to wait for my custom console gauge and shifter plates to come in. Once I have those in hand I can start messing with the boot. Right now I have the cardboard templates the I can mess with to get some measurements. I'll keep you posted if I come up with something. Meantime anyone else... (IMG:style_emoticons/default/unsure.gif) |
mepstein |
Feb 23 2021, 01:37 PM
914-6 GT in waiting Group: Members Posts: 19,215 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I would make one out of vinyl from the back of an old 914 seat and then have an upholstery shop or fabric shop reproduce it in leather.
ClayPerrine |
Feb 23 2021, 01:59 PM
Life's been good to me so far..... Group: Admin Posts: 15,388 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
So while I wait on some sheet metal to come in I've been working on some interior stuff. I'm going to run a RennShifter with a center console. I do not like the shifter boot supplied. It looks like a cv joint boot to me. I'm thinking of a leather boot for it. Anyone running the above setup that can post a few pics and where you may have gotten the boot from? TIA, Luke... You have no pedals, no steering gear, and no wiring. You have WAY more things to worry about than a shifter boot. (IMG:style_emoticons/default/poke.gif) |
mepstein |
Feb 23 2021, 02:03 PM
Things that keep you up at night. (IMG:style_emoticons/default/laugh.gif)
Van914 |
Feb 23 2021, 02:11 PM
Van914 Group: Members Posts: 698 Joined: 5-January 03 From: Cincinnati, Ohio Member No.: 90 Region Association: Upper MidWest |
Use on for a 986 Boxster. Plenty on eBay. You can even chose your color.
(IMG:style_emoticons/default/driving.gif) |
burton73 |
Feb 23 2021, 04:48 PM
burton73 Group: Members Posts: 3,484 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
double-a |
Feb 23 2021, 05:05 PM
Senior Member Group: Members Posts: 987 Joined: 15-September 03 From: vancouver, wa, usa Member No.: 1,162 Region Association: Pacific Northwest |
So while I wait on some sheet metal to come in I've been working on some interior stuff. I'm going to run a RennShifter with a center console. I do not like the shifter boot supplied. It looks like a cv joint boot to me. I'm thinking of a leather boot for it. Anyone running the above setup that can post a few pics and where you may have gotten the boot from? TIA, i also have a center console with a Rennshift, and although it was fairly tricky, i was able to solve this problem last fall. you will have to build a customized bottom panel. here's how i did it. first, i used a 911 SC-style boot — much better appearance, and they can be affixed to the underside of the panel as a final step, similar to how the factory 914 center console shift boot is attached. to build the panel, i made several iterations using foam core panels at first. then i used the most accurate of these templates to trace and cut a version out of 1/4" plywood, and iterated a couple times on that. if you intend to cover it with thin foam + vinyl as i did, remember to account for the extra thickness. i found the install to be pretty tricky due to how close the larger diameter shifter body is to the inside of the left console panel. it's TIGHT in there. i will get some pictures for you. |
yeahmag |
Feb 23 2021, 05:36 PM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
I don't see the shift adjuster window on the back of that Rennshift. How do you adjust it?
Luke M |
Feb 23 2021, 06:10 PM
So while I wait on some sheet metal to come in I've been working on some interior stuff. I'm going to run a RennShifter with a center console. I do not like the shifter boot supplied. It looks like a cv joint boot to me. I'm thinking of a leather boot for it. Anyone running the above setup that can post a few pics and where you may have gotten the boot from? TIA, Luke... You have no pedals, no steering gear, and no wiring. You have WAY more things to worry about than a shifter boot. (IMG:style_emoticons/default/poke.gif) Thanks for noticing that Clay... (IMG:style_emoticons/default/lol-2.gif) My metal work is on hold while I wait on some sheet metal to get here from out West. Engine is on hold waiting for parts but the trans is done. So I went and messed around with the interior stuff. Figured chip away at the list even if it's not on the chassis. Do it now or later, either way it needs to get done. (IMG:style_emoticons/default/shades.gif) |
Luke M |
Feb 23 2021, 06:15 PM
So while I wait on some sheet metal to come in I've been working on some interior stuff. I'm going to run a RennShifter with a center console. I do not like the shifter boot supplied. It looks like a cv joint boot to me. I'm thinking of a leather boot for it. Anyone running the above setup that can post a few pics and where you may have gotten the boot from? TIA, i also have a center console with a Rennshift, and although it was fairly tricky, i was able to solve this problem last fall. you will have to build a customized bottom panel. here's how i did it. first, i used a 911 SC-style boot — much better appearance, and they can be affixed to the underside of the panel as a final step, similar to how the factory 914 center console shift boot is attached. to build the panel, i made several iterations using foam core panels at first. then i used the most accurate of these templates to trace and cut a version out of 1/4" plywood, and iterated a couple times on that. if you intend to cover it with thin foam + vinyl as i did, remember to account for the extra thickness. i found the install to be pretty tricky due to how close the larger diameter shifter body is to the inside of the left console panel. it's TIGHT in there. i will get some pictures for you. I had the same issue with fit too. It's diffidently tight on the left side. I have a cardboard template made up and seams like things will fit ok. When you get a chance post your pics. Thanks. |
ClayPerrine |
Feb 24 2021, 08:06 AM
Luke... You have no pedals, no steering gear, and no wiring. You have WAY more things to worry about than a shifter boot. (IMG:style_emoticons/default/poke.gif) Thanks for noticing that Clay... (IMG:style_emoticons/default/lol-2.gif) Happy to be of service.. (IMG:style_emoticons/default/biggrin.gif) Clay |
VaccaRabite |
Feb 24 2021, 08:19 AM
En Garde! Group: Admin Posts: 13,417 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I made the boot for my shifter with about $5 worth of vinyl from JoAnne's and maybe 10 minutes of sewing time.
Just make a paper pattern first and its no problem. Super super easy. Zach |
double-a |
Feb 24 2021, 12:12 PM
Anyone running the above setup that can post a few pics and where you may have gotten the boot from? TIA, sorry for the delay. here's a shot of the template, and the finished installed panel. it was extremely tricky to get right, and i'm about 95% happy with it. getting the panel in and out requires some careful prying of the console left panel, plus plenty of cajoling and the use of not a few colorful metaphors. |
Luke M |
Feb 24 2021, 12:27 PM
Anyone running the above setup that can post a few pics and where you may have gotten the boot from? TIA, sorry for the delay. here's a shot of the template, and the finished installed panel. it was extremely tricky to get right, and i'm about 95% happy with it. getting the panel in and out requires some careful prying of the console left panel, plus plenty of cajoling and the use of not a few colorful metaphors. I ran into the same issue getting the template on/off. I'm gonna go with a leather shift boot now that I see yours installed with the center console. Thanks for adding the pics. |
Lo-Fi Version | Time is now: 18th April 2024 - 04:55 AM |
