"elluva a hole. Still welding after all these years..., latest -did the factory run out of jacking doughnuts? |
worn |
Feb 24 2021, 10:40 AM
can't remember Group: Members Posts: 3,153 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
See last post. Welding and rubber sealant removal coming to the end. Thanks.
Haven't been very active for a couple of years. Partly because the 911 has taken up my time. So I am finally getting around to rust repair on my '76. The floors have rusted through so I have been working on the layer cake that makes up the right side longitudinal, focused on the hell region. The rust has affected both the inner pieces as well as the outer ones, and it is concentrated where all of the pieces come together. I have cut away the pitted and perforated metal. My question is as follows. I am addressing the problem by restoring each piece to produce a longitudinal as it came from the factory. For example. In this case I made a piece to restore the tab of the forward inner layer of the outside long. Then I added a piece to restore the rear inner layer piece the overlaps: Then I have made a patch for the outer wheel house piece to produce the outer layer. The patches are butt welded to good metal on the original pieces and shaped to reproduce the originals. Here is the question. Is this really best practice? For example, instead of making a bunch of pieces that join together to match the original I could use a single sheet that replaces them all at once. With fewer butt welds and seams. My method so far has been heavily influenced by threads from people I admire here on the world. You folks make nice welds. |
FourBlades |
Mar 27 2021, 08:56 AM
From Wreck to Rockin Group: Members Posts: 2,054 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
worn |
Mar 31 2021, 08:47 AM
Yep. Moving to the outside layer cake. I really hoped that the left side would be better, but it is slightly worse. Looks like the Counting Crows hit the nail squarely on the head. It was probably Raining in Baltimore much of this car's life. At any rate this shows three layers of metal. There is the front outer long: rusted at the last two inches. This panel is made by RD, but that is a lot of cutting to patch that little part. In the rear there is the outer layer that goes on to make the wheel house and then a strengthening layer (with the punched large holes. This is made out of stronger steel. Fortunately I have a punch set. Not sure how close a match they are yet. Farther in the hole are the weld back sides of the repair of the inside long. Screws poking in are temporary: have to get them out and finish those plug welds. Question for anyone who might know. Is it possible to replace the jack point without cutting out the fender and sill? I don't see how, but still wonder. |
worn |
Jan 11 2022, 01:27 PM
Been awhile but in the mean time I have been remodeling some rooms, rebuilding the 911 engine, and getting gifts made for x-mas (shaping and grinding Damascus steel kitchen knives).
Returning to the left side: like the right side I worked from inside out. Replacing the rear end of one piece. This inner piece to the rear is overlapping the first patch. As before, I am replacing ends or bottom areas of a large piece. Matching the holes originally there was a PITA and perhaps I should have just them out, but here they are a bit of the ugly. The hole towards the front is behind a depression in the next piece that overlaps. The depression is for the jack point. Attached thumbnail(s) |
worn |
Jan 11 2022, 01:32 PM
worn |
Jan 11 2022, 01:36 PM
worn |
Jan 11 2022, 01:44 PM
mb911 |
Jan 11 2022, 01:55 PM
914 Guru Group: Members Posts: 6,830 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Speaking of RD wonders, here is the rear part of the box beam that connects the longs from side to side. Note the cuts needed to get past the heater tubes. For the parking brake and heater control tubes I took them out and will be brazing them back in. That was a killer on mine. Bled through in a few spots and had to get very creative to get the cables through |
Lo-Fi Version | Time is now: 7th May 2024 - 07:29 AM |
