"elluva a hole. Still welding after all these years..., latest -did the factory run out of jacking doughnuts? |
worn |
Feb 24 2021, 10:40 AM
can't remember Group: Members Posts: 3,153 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
See last post. Welding and rubber sealant removal coming to the end. Thanks.
Haven't been very active for a couple of years. Partly because the 911 has taken up my time. So I am finally getting around to rust repair on my '76. The floors have rusted through so I have been working on the layer cake that makes up the right side longitudinal, focused on the hell region. The rust has affected both the inner pieces as well as the outer ones, and it is concentrated where all of the pieces come together. I have cut away the pitted and perforated metal. My question is as follows. I am addressing the problem by restoring each piece to produce a longitudinal as it came from the factory. For example. In this case I made a piece to restore the tab of the forward inner layer of the outside long. Then I added a piece to restore the rear inner layer piece the overlaps: Then I have made a patch for the outer wheel house piece to produce the outer layer. The patches are butt welded to good metal on the original pieces and shaped to reproduce the originals. Here is the question. Is this really best practice? For example, instead of making a bunch of pieces that join together to match the original I could use a single sheet that replaces them all at once. With fewer butt welds and seams. My method so far has been heavily influenced by threads from people I admire here on the world. You folks make nice welds. |
Dion |
May 24 2022, 07:39 AM
RN Group: Members Posts: 2,764 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region |
Wow, way to go Warren. That was a task. Well done.
worn |
May 25 2022, 10:58 AM
Kept hitting my head while backing out of the engine bay. My solution.
I finished up the rear with a couple patches where metal was in layers surrounded by failed sealant. My favorite was this one, which spans two pressings - the rear fender overlaps the piece that covers the rear of the trunk. The two pieces were made separately and plug welded together before welding to the car. I flattened some of the left overs from the trunk floor piece and then reshaped. The seam is crooked, but I am not going to fix it. |
worn |
May 25 2022, 11:04 AM
Another hole found. I had to buy the B-pillar pressings twice because I originally thought the rust didn't go all of the way to the top and fixed only the bottom. Had to carefully try to remove the plug welds, which is harder than drilling out spot welds.
This shows the new excavation with earlier fix still present. |
worn |
May 25 2022, 11:17 AM
You can buy the B-pillar, but not the piece of the upper inner wheel housing. This goes from the engine bay all of the way through into the cabin. Again I hadn't bought my galvaneal sheet, so I flattened out a piece of trunk scrap.
You can buy the tube that lets air move in and out of the cabin, but by the time I was done I had carved most of it away. The piece that holds the tube also holds the door latch plate. You can buy the piece that holds the door latch along with the nut plate. But, you can't buy the little box that houses the nut plate. I have seen some cars where the factory just used a strapp across the middle of the nut plate. This is a '76 and the box and nut plate were liberally covered in sealer...thus the need for repair (IMG:style_emoticons/default/blink.gif) I used silver bearing brazing rod to attach the tube, but epoxy wold probably be just as good. |
Lo-Fi Version | Time is now: 7th May 2024 - 09:16 AM |
