Tangerine fuel lines, Which hose to use? |
Planeswalker33 |
Feb 27 2021, 12:15 PM
Newbie Group: Members Posts: 23 Joined: 27-May 20 From: Southern California Member No.: 24,319 Region Association: Southern California |
I’m installing a complete set from Tangerine racing to replace the lines on my 75 1.8l. I’m confused on two portions.
First, where should I use the elbows that come with the kit? Second, can I just use the 7.9mm fuel hose to attaché the stainless tubes from the tunnel to those in the engine bay? I feel like I’m supposed to use the elbows with smaller hose there. Last the tubes in the engine bay are snug and pushing against each other slightly and will not fit into the lower clips. Am I fitting this wrong? I’m concerned they’ll rattle the way they are currently only in grommets and the upper fitting. I appreciate any help. Still very new to all this. Thanks! Attached thumbnail(s) |
Planeswalker33 |
Feb 27 2021, 12:17 PM
I still don’t understand why my mobile pictures flip upside down. Here’s another shot. Is this correct?
ndfrigi |
Feb 27 2021, 03:15 PM
Advanced Member Group: Members Posts: 2,926 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
ChrisFoley |
Feb 28 2021, 05:44 AM
I am Tangerine Racing Group: Members Posts: 7,907 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
914s came with other type retention clips on earlier models. There's no "exact fit" replacement hard line.
The plastic lines had more give, so could follow the car's shape more easily. My stainless lines are my best compromise shape based on the oem ones installed in early model years. '75-76 had continuous plastic lines from under the fuel tank to the engine compartment. You could probably tweak the shape of those stainless lines just a little bit if you want them to fit more closely in your car. The only elbows in a fuel line kit are to replace the Injector hose elbows. |
sjhenry1075 |
Mar 1 2021, 08:22 AM
Member Group: Members Posts: 266 Joined: 22-July 12 From: Stevensville, MD Member No.: 14,709 Region Association: North East States |
Make sure you use fuel line specifically designed for your setup. If you have FI you'll need something that can handle high pressure, otherwise you'll have a lot of leaks.. (ask me how I know..)
Lo-Fi Version | Time is now: 18th April 2024 - 09:04 PM |
