Fs 2.2T engine kit, Some assembly required |
BK911 |
Feb 27 2021, 07:30 PM
Senior Member Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
Completely disassembled 2.2T engine.
Was running when parked. (IMG:style_emoticons/default/biggrin.gif) No visible damage on anything so should make a nice core to build a nice little hotrod engine. No idea on price. $5k/obo??? |
BK911 |
Feb 27 2021, 10:46 PM
No pics yet.
This stuff is all boxed up in my basement. But it looks like a 2.2T engine in pieces. (IMG:style_emoticons/default/biggrin.gif) 70 or 71 2.2T sporto engine. Also have manifolds and zeniths. Air cleaner, alt/fan, shroud, engine wire harness, dizzy, etc... |
davep |
Feb 28 2021, 11:00 AM
914 Historian Group: Benefactors Posts: 5,137 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Give me the engine serial # please. And if you can, get the casting part #'s from both sides under the oil return tubes; 101.xR and 102.xR the x's are the important part with the 1&2. So you are saying the case has been split?
BK911 |
Feb 28 2021, 12:15 PM
BK911 |
Feb 28 2021, 06:07 PM
Heads:
Cam boxes on top, zeniths on bottom: Pistons/cylinders: |
roblav1 |
Mar 3 2021, 05:57 PM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
2.2T has non counterweight crank. Some people prefer that for racing.
BK911 |
Mar 4 2021, 06:15 AM
That is true.
The non counter weighted crank does spin up faster. However, my original plans for this engine was a 2.4 crank/rods and an E cam. 2.2T pistons have a higher dome than 2.4 pistons so you get a higher compression 2.4E engine. That's what I put in most of my early cars. VERY fun engine. Plus carb heads flow more air than a MFI head. |
BK911 |
Mar 6 2021, 07:49 AM
No longer available.
Lo-Fi Version | Time is now: 3rd May 2024 - 10:14 PM |
