I found the leakMaybe three of you would have a clue. |
pcdarks |
Feb 27 2021, 07:56 PM
Member Group: Members Posts: 80 Joined: 22-June 13 Member No.: 16,037 Region Association: None |
I just finished rebuilding my 72 1.7lL and had an elusive oil leak. It would show up on the alternator, crossmember that holds the engine and the shift rod. I have a car lift and was able to get good observation of the area but still could not find the leak. It would not show up on idling the engine but if I took it out and drove it it would leak like a sieve. This is a picture of the block when I rebuilt it and it shows where it was coming from. Just like "where's Waldo" who can find the leak? Hint: it's part of the block on the drivers side.
bbrock |
Feb 27 2021, 08:25 PM
Dip stick tube.
ejm |
Feb 27 2021, 09:07 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,690 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
Threaded hole for the thermostat pulley bolt
hcdmueller |
Feb 27 2021, 10:26 PM
????????????? Group: Members Posts: 542 Joined: 4-February 06 From: UK Member No.: 5,527 Region Association: England |
Threaded hole for the thermostat pulley bolt (IMG:style_emoticons/default/agree.gif) I may have left the pulley off my bus motor at one point. |
iankarr |
Feb 27 2021, 11:22 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,472 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Def thermostat pulley bolt
bandjoey |
Feb 27 2021, 11:30 PM
bandjoey Group: Members Posts: 4,923 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
All of the above
barefoot |
Feb 28 2021, 07:52 AM
Senior Member Group: Members Posts: 1,270 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Oil pump, Taco plate cover, front main seal
brant |
Feb 28 2021, 08:37 AM
914 Wizard Group: Members Posts: 11,617 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Tons of people have made the same mistake with the pulley
rgalla9146 |
Feb 28 2021, 09:14 AM
Advanced Member Group: Members Posts: 4,545 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Oil galley plug ?
Ray do you concur ? |
SirAndy |
Feb 28 2021, 11:32 AM
Resident German Group: Admin Posts: 41,609 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Threaded hole for the thermostat pulley bolt (IMG:style_emoticons/default/agree.gif) I may have left the pulley off my bus motor at one point. (IMG:style_emoticons/default/agree.gif) The pulley bolt hole goes all the way through into the case. Seen it many times on "performance" rebuilds where some misguided soul thought that removing the cooling flaps would somehow make the engine run cooler. (IMG:style_emoticons/default/screwy.gif) |
Highland |
Feb 28 2021, 11:40 AM
Senior Member Group: Members Posts: 512 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
The “2nd” oil pressure relief valve?
bbrock |
Feb 28 2021, 11:48 AM
... It would show up on the alternator, crossmember that holds the engine and the shift rod... ... It would not show up on idling the engine but if I took it out and drove it it would leak like a sieve... ... This is a picture of the block when I rebuilt it and it shows where it was coming from. I'm doubling down on dip stick tube. |
Dave_Darling |
Feb 28 2021, 06:15 PM
914 Idiot Group: Members Posts: 14,981 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I agree with all the folks who said the pulley bolt hole. Especially since it only showed up while driving, when the oil is sloshing around.
--DD |
GregAmy |
Feb 28 2021, 07:50 PM
Advanced Member Group: Members Posts: 2,281 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
I may have left the pulley off my bus motor at one point. (IMG:style_emoticons/default/aktion035.gif) Pissed me off when I figured it out. (I installed Tangerine's remote oil cooler which removes the flapper system). Edit: still pisses me off thinking about it later. |
Sycolyst |
Mar 1 2021, 12:42 PM
Newbie Group: Members Posts: 42 Joined: 20-July 19 From: Northern Ohio Member No.: 23,312 Region Association: Upper MidWest |
pcdarks |
Mar 1 2021, 04:05 PM
Lo-Fi Version | Time is now: 1st May 2024 - 06:28 PM |
