PCCM Install |
PCCM Install |
stickyfingers |
Feb 28 2021, 12:03 AM
Member Group: Members Posts: 164 Joined: 19-February 21 From: Toronto Member No.: 25,223 Region Association: Canada |
Good evening folks,
I’ve got someone selling me a used Porsche Classic Navigation Radio. Apparently I was told I need to get a radio plate. Could someone let me know which one of the two available on 914rubber may work for my application so I can get the new PCCM in there? I have the factory am/fm radio in the car currently as shown below. I believe the pattern I have is the brickmold - can someone confirm before I place the order? 2nd Question: Do I need the factory option or the Single DIN based off my current getup. Thanks yet again. |
Chris914n6 |
Feb 28 2021, 02:50 AM
Jackstands are my life. Group: Members Posts: 3,287 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Single DIN, assuming the PCCM is a standard single DIN.
The hole in the dash frame is single DIN with the exception of the rounded corners which I had to square up with a chisel slightly. The PCCM likely bolts in instead of using a sleeve, so you will need to make mounts, though a generic sleeve might work but wouldn't lock, or it might match the sleeve of whoever actually made the unit (Panasonic/Clarion/Blaupunkt/???) I feel like I've said this before..... |
bbrock |
Feb 28 2021, 09:30 AM
Single DIN and yes, that is brickmold. FWIW, I installed a new Blaupunkt not long ago and made my own single DIN face plate. The sleeve that came with that radio slid right into the dash opening without modification. Here is a video showing the PCCM install.
https://www.youtube.com/watch?v=V74qjRuzTlU |
stickyfingers |
Feb 28 2021, 11:08 AM
Thanks. I called my Porsche dealer and the service tech stated that I definitely needed to get either of those plates because there is lots of room around after the PCCM is installed so it makes sense to get the Single DIN plate to get this installed properly. I'll send some pics once it's installed once I get my hands on that pccm.
@bbrock I've seen that video as well. Wish someone had a video or images of this on a 914 - searched high and mighty and can't locate anyone that's done this in a 914 and their experience with it. |
bbrock |
Feb 28 2021, 11:37 AM
@bbrock I've seen that video as well. Wish someone had a video or images of this on a 914 - searched high and mighty and can't locate anyone that's done this in a 914 and their experience with it. It should be pretty much the same process. A single DIN opening is a standard that is supposed to be the same size regardless of the car it is in. Like Chris said, you might have to tweak the rounded corners a little on the dash opening (not the face plate) but otherwise should slide in the same. Your bigger challenge will be the wiring harness since the PCCM is designed to plug into a modern factory harness. I'll bet you could find a wiring kit on Crutchfield that has the right plug connectors. I'd give them a call. |
stickyfingers |
Feb 28 2021, 01:24 PM
I've got a good local guy to help with that. He's sourcing the PCCM and the labour would be relatively cheap (he's done work on some of my cars in the past for a radio/electronics perspective. Thanks.
Chris914n6 |
Feb 28 2021, 08:11 PM
Informative video.
You know the only other car I've seen with a slide in HU... the New Beetle (IMG:style_emoticons/default/av-943.gif) The 993 connectors look similar to my 06 GTI, in which case finding them will be easy. Won't get the unit wired up without them. The antenna lead is funky too = adapter. You will also likely need to run a dedicated fuse as the unit will draw more power and the stock 914 stereo fuse draws off some other stuff too. Nice looking unit, but with a list of $1500 I'll keep my $100 HU w/BT and phone and tether my 8" tablet for nav. |
stickyfingers |
Mar 1 2021, 07:08 AM
Informative video. You know the only other car I've seen with a slide in HU... the New Beetle (IMG:style_emoticons/default/av-943.gif) The 993 connectors look similar to my 06 GTI, in which case finding them will be easy. Won't get the unit wired up without them. The antenna lead is funky too = adapter. You will also likely need to run a dedicated fuse as the unit will draw more power and the stock 914 stereo fuse draws off some other stuff too. Nice looking unit, but with a list of $1500 I'll keep my $100 HU w/BT and phone and tether my 8" tablet for nav. Which one do you use? |
stickyfingers |
Aug 22 2022, 03:53 PM
Finally jumped in head first and installed the PCCM. The sound is phenomenal with the built-in amp/equalizer in the PCCM. I haven't had issues with the brightness of the display although I had the top on and it was really sunny. I will try with the top off and see if it bothers me. The handsfree for phone calls is amazing.
Pics below: |
mmichalik |
Aug 22 2022, 04:17 PM
MikeM Group: Members Posts: 687 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California |
That looks really nice. Very clean install.
Makes me want to rethink my radio situation in the 75. |
emerygt350 |
Aug 22 2022, 05:01 PM
Advanced Member Group: Members Posts: 2,025 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Man, I like your old radio....
Cairo94507 |
Aug 23 2022, 01:28 PM
Michael Group: Members Posts: 9,650 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
I love that new radio in your dash. I wish I could bring myself to do that swap but my Blaupunkt Saphire looks the part and as an added bonus, it works.
stickyfingers |
Aug 23 2022, 08:36 PM
It was a pricey upgrade but it makes me happy. Lol.
The classic radio never worked for me. The Bluetooth cheapy amp from Amazon was decent but the quality of this has been outstanding and in my mind well worth the upgrade. I had to spend a bit of extra time to slight shave the slot as the pccm is slight (2 mm) wider or so. |
Freezin 914 |
Aug 23 2022, 08:52 PM
Senior Member Group: Members Posts: 825 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest |
It was a pricey upgrade but it makes me happy. Lol. The classic radio never worked for me. The Bluetooth cheapy amp from Amazon was decent but the quality of this has been outstanding and in my mind well worth the upgrade. I had to spend a bit of extra time to slight shave the slot as the pccm is slight (2 mm) wider or so. I am assuming you had to hard wire it? Or were you able to find a wiring harness adapter that worked? It does give the dash a bit of a modern look. (IMG:style_emoticons/default/beerchug.gif) |
ClayPerrine |
Aug 24 2022, 08:43 AM
Life's been good to me so far..... Group: Admin Posts: 15,367 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I actually like it and was considering it.
Then I looked at the price. $1500.00. (IMG:style_emoticons/default/pinch.gif) |
bbrock |
Aug 24 2022, 09:12 AM
I actually like it and was considering it. Then I looked at the price. $1500.00. (IMG:style_emoticons/default/pinch.gif) Yeah, I did the same and I believe the navigation map subscription is extra to boot. It would be nice if they offered these without navigation but with Android Auto/Apple Car Play so you could just display your phone navigation on the screen. And that price would need to get below $500 before I'm a player. |
stickyfingers |
Aug 24 2022, 03:10 PM
It was a pricey upgrade but it makes me happy. Lol. The classic radio never worked for me. The Bluetooth cheapy amp from Amazon was decent but the quality of this has been outstanding and in my mind well worth the upgrade. I had to spend a bit of extra time to slight shave the slot as the pccm is slight (2 mm) wider or so. I am assuming you had to hard wire it? Or were you able to find a wiring harness adapter that worked? It does give the dash a bit of a modern look. (IMG:style_emoticons/default/beerchug.gif) Yea - it wasn't too bad. I need a constant power lead from the battery. Had one already sitting behind the dash from PO. Took 12v from the lighter plug and hooked the speakers, mic, etc... The navigation is separate if you want the porsche maps. I just use carplay w/waze and apple music and it works great. |
914e |
Aug 24 2022, 08:44 PM
Member Group: Members Posts: 496 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
I actually like it and was considering it. Then I looked at the price. $1500.00. (IMG:style_emoticons/default/pinch.gif) Yeah, I did the same and I believe the navigation map subscription is extra to boot. It would be nice if they offered these without navigation but with Android Auto/Apple Car Play so you could just display your phone navigation on the screen. And that price would need to get below $500 before I'm a player. Most of the aftermarket players with navigation are in the same price range, none of them are single DIN units. On the other hand I don't think my eyes work with that tiny screen anymore. |
bbrock |
Aug 24 2022, 09:40 PM
I actually like it and was considering it. Then I looked at the price. $1500.00. (IMG:style_emoticons/default/pinch.gif) Yeah, I did the same and I believe the navigation map subscription is extra to boot. It would be nice if they offered these without navigation but with Android Auto/Apple Car Play so you could just display your phone navigation on the screen. And that price would need to get below $500 before I'm a player. Most of the aftermarket players with navigation are in the same price range, none of them are single DIN units. On the other hand I don't think my eyes work with that tiny screen anymore. Yep. Just bought a double DIN head unit for the DD and got the same sticker shock with navigation units. Got a nice unit with similar features but without navigation for $300. Navigation is kind of obsolete with Carplay and Android Auto. I would think Porsche would have a lot of takers for a unit sans nav. |
PanelBilly |
Aug 25 2022, 01:57 PM
914 Guru Group: Members Posts: 5,788 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I looking to put one in the 968 without NAV. The OEM unit I got with the car was spec’s for GB and while it’s cool looking, not for listening in the states.
Lo-Fi Version | Time is now: 29th March 2024 - 03:08 AM |
