Where to buy bolts, Does it matter where you buy them |
Dredwin |
Mar 1 2021, 11:51 AM
Member Group: Members Posts: 71 Joined: 21-December 13 From: Colorado Springs Member No.: 16,783 Region Association: Rocky Mountains |
I am needing to replace some CV bolts for a larger axle. They are M8 with 1.25 thread (12.9) and 56MM top to bottom. Are bolts relatively the same if they are the right size and strength? Suggestions on where to buy?
bdstone914 |
Mar 1 2021, 12:54 PM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
You just need to buy the correct 12 point CV bolts carried by most of the common vendors.
Mark Henry |
Mar 1 2021, 01:22 PM
I am needing to replace some CV bolts for a larger axle. They are M8 with 1.25 thread (12.9) and 56MM top to bottom. Are bolts relatively the same if they are the right size and strength? Suggestions on where to buy? Could you elaborate on the above point in bold. Bolts are measured not counting the head. 56mm sounds right, but did you measure correctly? You also need new schnorr washers (my spelling may be off). VW aircooled shops also have these bolts. |
Mikey914 |
Mar 1 2021, 04:45 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The CV bolts are hardened, and not all that expensive.
You can find bolts for less but there is engineering that has went into the correct hardness. You may save a few bucks but personally I'd just buy them from one of the usual vendors, as you know the spec is correct. |
aharder |
Mar 1 2021, 05:55 PM
Advanced Member Group: Members Posts: 4,370 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region |
(IMG:style_emoticons/default/agree.gif) don’t cut corners on those
Dredwin |
Mar 1 2021, 10:05 PM
Thanks all. This is a Renegade built car so i know the bolts are not the ones listed for the car. The axle is a bigger axle with an adapter that bolts on the transmission. Basically 6 bolts attach to the piece that has 4 bolts (original bolts) that attaches to the transmission. The bolts I am looking for are actually 56mm in total length with around 47mm (45?) below the head. I am not bargain shopping, just want the correct bolts. I’ll look at the VW shop and see if the bolts I found on Pelican were correct (now that I know what I was measuring)
Mike Bellis |
Mar 1 2021, 10:43 PM
I get my longer, hardened bolts from boltdepot.com I use these on my 930 CV's .
Front yard mechanic |
Mar 2 2021, 09:07 AM
Senior Member Group: Members Posts: 1,154 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
Longer and harder |
AZBanks |
Mar 2 2021, 02:55 PM
Senior Member Group: Members Posts: 1,055 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region |
Lo-Fi Version | Time is now: 24th April 2024 - 08:23 PM |
