Rebuild Recommendations, 1.7 FI |
RogerYellow914 |
Mar 2 2021, 12:12 AM
Member Group: Members Posts: 72 Joined: 4-December 05 From: Redlands, CA Member No.: 5,230 |
I’ve decided to rebuild my car’s original 1.7 with FI. It ingested an exhaust valve which put a hole in a piston.
Everything is apart. Found the crank and cam bearings to be in great shape. Haven’t taken the rods off the crank, but they move smoothly. Looking at P&C sets not finding much in 90mm. And if I believe rebuilding or replacing the heads will cost about the same if machined for 90mm - 96mm. What are the pros/cons to increasing bore with a stock 66mm stroke? Is there a limit to what the stock D-Jet can handle? I appreciate your collective wisdom. -Roger |
Lo-Fi Version | Time is now: 18th May 2024 - 07:48 PM |
