Ljet vacuum hose, Any scuba divers on this site? |
timothy_nd28 |
Mar 2 2021, 04:39 PM
In the process of re-doing vacuum lines on my 1.8L Ljet. The vacuum line that has given me trouble before is the 22mm (blue in picture) which I cobbled together with less than desirable results.
I'm toying with the idea of using a hose from most scuba setups, the BCD corrugated inflator hose. It is rubber of some type, the ID diameter appears to be very similar, and I like the idea that it looks very flexible so it can be routed to look somewhat stock vs what I had before. Question is, what is this made out of, and how will it hold up? |
Mark Henry |
Mar 3 2021, 11:51 AM
Giving away one of my secrets but stick a short chunk of 1" aluminum mandrel bend into the hose. Make sure to round over the sharp ends of the tube, use lube and there's your tight bend without collapsing the hose. |
Lo-Fi Version | Time is now: 19th May 2024 - 03:25 AM |
